Author Topic: Kymco ck1 fuse location  (Read 932 times)
John s
« on: May 14, 2020, 07:27:09 PM »
Hello can anyone tell me where the fuses are located on a 2014 ck1 please
Re: Kymco ck1 fuse location
« Reply #1 on: May 14, 2020, 07:59:24 PM »
Owners manual?
USUALLY, one will find a free pdf download for an owners manual for nearly any Kymco scooter, motorcycle or mobility chair. I did not know they even made a 125 motorcycle! Added to the large amount I don't know! There are not too many places to hide anything on a motor bike so my first guess would be to remove the seat. That is if the fuse block not in some convenient snap latch compartment.
« Last Edit: May 14, 2020, 08:15:39 PM by CROSSBOLT »
John s
« Reply #2 on: May 14, 2020, 08:09:12 PM »
I have the owners manual but there are several pages missing
« Reply #3 on: May 14, 2020, 08:18:07 PM »
Just caught your reply! Your mission then is like what I posted above. I could not find a freebie manual on line. So you stuck for now to explore!
By the way, where are you located? You may want to put your location in your profile because so far, you the only one with this model. That makes YOU the expert!
« Last Edit: May 14, 2020, 08:20:47 PM by CROSSBOLT »
John s
« Reply #4 on: May 15, 2020, 10:06:02 AM »
I’m located in England. The reason I ask is that I am trying to rectify a fault in which neither brake light is working on the bike. I have replaced the bulb but the fault is still there. I’m thinking maybe there is a fuse for the brake lights?  I can not locate any of the fuses which are apparently right next to the battery. I have no manual to consult.
« Reply #5 on: May 15, 2020, 12:37:33 PM »
You are starting at the right place by trying to check fuses first. Are there or is there a place to stow a tool kit?
