Author Topic: Kymco Like 200i Scooter Valve Clearance Adjustment  (Read 10165 times)
« on: May 17, 2020, 06:35:44 PM »
Great video.
Two points:
It is not necessary to remove the battery - just place a heavy cloth over the battery.
Also, please check for a slight movement in the rocker arms to insure that you are at TDC - if there is no movement you could be 360 degrees off, and you will need to rotate the engine again.
Major Tom
« Last Edit: June 19, 2020, 08:59:00 PM by Stig / Major Tom »
RonnieFranchise
Re: Kymco Like 200i Scooter Valve Clearance Adjustment
« Reply #1 on: February 17, 2022, 05:50:05 AM »
Great video.
Two points:
Will this be the same spec/procedure on my Like 150i ?  And do you know where I can find a book on torque specs, etc. for my 150i?
Major Tom
« Reply #2 on: February 17, 2022, 09:04:42 AM »
No.
Different engine. Different method of getting to the valve cover.
Www.cyclepedia.com has service manual for your scooter, with torque specs, etc.
There may be a YouTube video for your scooter model. I do not know...I've never looked.....
Also, Welcome to the forum!
mojorising
« Reply #3 on: January 24, 2023, 06:47:26 AM »
i have a 150i and ive done the valve adjustment multiple times. there are 4 of them that need to be adjusted. my service manual suggests intake set to .12mm and exhaust set to .12mm. However ive found that is way too loose and i set mine to intake .003mm and exhaust to .004mm. Hope this helps
