Author Topic: rear suspension removal  (Read 731 times)
Footsoldier2008
« on: May 22, 2020, 03:23:19 PM »
hi does anyone know how to remove the rear suspension on a agility 125 ?
Many thanks
big blue
Re: rear suspension removal
« Reply #1 on: May 22, 2020, 04:56:02 PM »
TBR125
  • East Tennessee, USA
« Reply #2 on: May 22, 2020, 06:38:03 PM »
Here is the way I did it. There are probably faster methods if you are proficient in plastic body removal.
1.   Place bike onto center-stand and set a block under the rear wheel to take the weight off the strut.
2.   Remove clamp bolt at the strut base and pull out blocks.
3.   Spend 2 hours with a ratcheting wrench removing the upper bolt with .5mm strokes; Or find a way to pull the plastic cover panel and use a ratchet.
Would be glad to hear how it goes. Good luck.
