Author Topic: Changing Tires  (Read 3519 times)
TBR125
  • East Tennessee, USA
Re: Changing Tires
« Reply #30 on: June 09, 2020, 11:41:09 PM »
I used a clamp on the rear brake while laying over the bike to smash the tire into the ground. It was a battle.
Vision
Re: Changing Tires
« Reply #31 on: June 09, 2020, 11:49:56 PM »
Finally got it off.
Here's a great video, am very impressed with this guy.
TBR125
Re: Changing Tires
« Reply #32 on: June 09, 2020, 11:56:33 PM »
I am humbled. Never realized the bead drop was for one side of the tire to ease installation. I am looking forward to the next tire change.
Thanks for pointing him out!
Vision
Re: Changing Tires
« Reply #33 on: June 12, 2020, 12:54:44 AM »
So I changed the rear tire...twice. Even trying to do it right I put it on backwards, not a fun time. It's hard sweaty work. The worst part is getting the old tire off once the bead has been broken.
On changing the front tire, does it come off with the brake disk on it? If so I have no idea how you world wrestle with it with that in the way.
TBR125
Re: Changing Tires
« Reply #34 on: June 12, 2020, 11:19:49 AM »
Glad you got! The front is easier to work with if you pull the four? disc bolts and remove it.
Vision
Re: Changing Tires
« Reply #35 on: July 30, 2020, 07:41:45 PM »
Anybody know the front axle nut size? Is it 17mm? The manual is wrong (on the rear).
TBR125
Re: Changing Tires
« Reply #36 on: July 30, 2020, 09:22:45 PM »
Rear nut is 24mm. Front is 14mm bolt head with 19mm nut.
Vision
Re: Changing Tires
« Reply #37 on: July 31, 2020, 11:42:33 AM »
Thanks
Re: Changing Tires
« Reply #38 on: February 11, 2021, 10:51:35 AM »
@TBR125,
just came across your tread and pics, well done.
Thanks alot.
TBR125
Re: Changing Tires
« Reply #39 on: April 19, 2021, 03:43:06 PM »
@TBR125,
Thanks alot.
Glad it helped. I've recently stepped up the challenge to changing my corolla tires. Need to find a semi-truck to break the bead though:)
