Author Topic: TA YOUNG Flasher Relay  (Read 1622 times)
TBR125
  • East Tennessee, USA
« on: June 06, 2020, 12:45:04 AM »
I found the problem with my scooter to be a dead flasher relay. I need to replace a D-401 TA YOUNG Flasher Relay. Do I have to order the same relay or will any other 3 pin 21W+21W+3.4W(14V 3W) relay work? What is a USA source for a genuine? With covid, shipping from Asia takes several months.
Thanks
Re: TA YOUNG Flasher Relay
« Reply #1 on: June 06, 2020, 11:09:08 AM »
Ebay?
Went to parts outlaw..does not list a "winker relay" for the 125 (wha-!) but a 38300 exists for nearly every other model. The difference seems a 38300 "winker relay" is 40 bucks for a DT300i and 30 bucks for a People 125!
Heck, even an Agility 50 has a winker relay!
Dan's Cycle has parts diagrams just like Parts Outlaw so no new news there. Kymco parts numbers practically identical to Honda so you might get some success with a Honda "winker relay." I would investigate any load independent flasher (with 3 wires) at auto parts....gotta be less than 30 bucks!
« Last Edit: June 06, 2020, 11:47:14 AM by CROSSBOLT »
TBR125
« Reply #2 on: June 06, 2020, 11:47:28 AM »
Ebay has about 20 USED kymco flasher relays for 20-25$ with 10$ shipping.
« Reply #3 on: June 06, 2020, 11:50:04 AM »
Thats nuts! Amazon?
TBR125
« Reply #4 on: June 06, 2020, 12:28:54 PM »
I ordered one from a shop coming out of California. Thanks.
« Reply #5 on: June 06, 2020, 03:32:38 PM »
TBR - looks like I'm late to this one...but when I needed a replacement for my flasher relay to work with led lights I just searched for 3 wire led flasher relays and had a million hits. Nothing specific about them. Typical price was around $10.
« Reply #6 on: June 06, 2020, 03:56:40 PM »
Now, THAT'S what I'm talkin' about!
TBR125
« Reply #7 on: June 06, 2020, 06:00:23 PM »
I bought a genuine just to have a stock part as a control unit. I built an adapter plug converting the original inline mini spade to standard separate spade for a normal relay such as you mentioned.
I might go led at some point. When I get through my 7 spare signal lamps.
TBR125
« Reply #8 on: June 09, 2020, 11:51:39 PM »
I got the relay today and it weighed almost nothing and didn't function. Pulled the cap....... it was an empty plastic shell. I am returning it of course and am worried about the starter relay coming from the same seller next week.
« Reply #9 on: June 10, 2020, 11:32:43 AM »
That is terrible! I hope they make good for you.
TBR125
« Reply #10 on: June 10, 2020, 11:50:41 AM »
It was cheap:) I have a standard auto type relay on the way. The time loss is the biggest irritation as this issue has cost me 2 weeks of lost transport.
I had to pull the bicycle back out.
« Reply #11 on: June 12, 2020, 02:20:19 PM »
So you all fixed now?
TBR125
« Reply #12 on: June 12, 2020, 02:50:52 PM »
I will be when the new battery comes in on Monday. The battery was trashed when sucked empty for a week which is ok as it was already on its 4th year. I have used the opportunity to do a complete rebuild maintenance. Repacking bearings, servicing brakes, removing superfluous emission systems etc. I had to remove the air injecting because the flange weld had broken and was leaking exhaust.
eamartin
« Reply #13 on: June 12, 2020, 03:44:20 PM »
Can you share brand and vendor information so no one else suffers the same fate?
TBR125
« Reply #14 on: June 12, 2020, 07:09:08 PM »
It was an honest error. The seller apparently got a bad batch and after two complaints of the same issue he contacted all buyers and replaced the relays free of charge. I have been very impressed with his actions and communication. I got the other relay and it is very good quality.
