Author Topic: Loose mirror  (Read 1514 times)
mine88
  • Kingston On Canada
Loose mirror
« on: June 06, 2020, 01:04:36 PM »
I am trying to fix loose mirror on my 2013 Xciting 500. Should the turn signal wire be disconnected first and will locktight help?
Re: Loose mirror
« Reply #1 on: June 06, 2020, 02:23:25 PM »
The lock nut should hold it. You don't have to disconnect the signal wire IF you are careful not to pinch it with your wrench.
mine88
Re: Loose mirror
« Reply #2 on: June 06, 2020, 07:25:00 PM »
The lock nut does not hold still vibrates loose will driving.
Re: Loose mirror
« Reply #3 on: June 06, 2020, 09:07:56 PM »
OK, I understand. Use Loctite blue, then. That should do it.
Re: Loose mirror
« Reply #4 on: June 12, 2020, 02:25:14 PM »
That do it for you?
mine88
Re: Loose mirror
« Reply #5 on: June 13, 2020, 01:38:03 PM »
Have not tried yet been busy with repairs to deck.
mine88
Re: Loose mirror
« Reply #6 on: July 13, 2020, 01:17:43 PM »
Used the locktite but only held for two weeks. The scooter shop said to use JB Weld . I have never heard of this will it work. Thanks for help
Re: Loose mirror
« Reply #7 on: July 13, 2020, 02:53:13 PM »
You will never be able to remove it with JB weld, if you break a mirror you will have to purchase a complete unit it screws into. What is worn out the threads on the mirror or threads in the perch? Are you loctiting the lock nut or the mirror threads or both?
mine88
Re: Loose mirror
« Reply #8 on: July 13, 2020, 05:41:05 PM »
I tried the blue locktite on the threads and the perch seemed solid at first but loosened off .
