Did you miss your
activation email
Scooters - 125 to 300
LIKE 200i
Trickle Charger
Topic: Trickle Charger (Read 249 times)
Groversmith
Newbie
Trickle Charger
June 10, 2020, 02:55:39 AM »
I have a solar powered trickle charger that plugs into the socket (in glovebox). Is that actually charging the battery?
TBR125
East Tennessee, USA
Re: Trickle Charger
June 10, 2020, 02:59:33 AM »
The 12v plug is the same as a battery extension lead. If the correct voltage(around 14v) is fed into the socket the battery will charge if it is in good condition.
Back
