Zero is not possible! Well, it's UNLIKELY! However it fits with your video sound track that I heard.
So, now, we get to the WHY of no compression. What I would suggest is to remove the air cleaner cover and inspect the filter, the inside of the cover and inlet. All air passages clear from cover snout to throttle body? If yes, then next:
Remove the cam/valve cover, just like you would do to check/set the valves. You can then check:
1. Timing chain in place?
2. Timing of cam correct?
3. Any thing look alarming with cam lobes, bearings, rockers, valve stems, springs & keepers?
Report back you findings and we'll go from there.
