Author Topic: 2007 Kymco Agility 50 electrical issues  (Read 285 times)
Jp6940
« on: June 15, 2020, 03:44:10 AM »
Sorry for not posting in the appropriate forum but looks like activity has slowed considerably and looks like I won’t get an answer...
Ok.
I’ve had led lights changed over for a few years without problems.  Recently when I squeeze the brake handle they would start flashing faster than normal.  When I let off they flash normally....?
Last week I went to flick the passing light switch and the headlight blew out.  Now it’s blown.
Hmmmmm.  So now when I turn on my blinkers they all come on but very faint.  Is it a short? Where shall I start? Just put a big bore kit on and it runs pretty well but no damn lights or blinkers!!
Brake light work great just as it is supposed to.
I’m a bit puzzled on this one.
7,000 miles on the scoot.  This is my first scoot and kinda close to it. Haha!
TBR125
  • East Tennessee, USA
Re: 2007 Kymco Agility 50 electrical issues
« Reply #1 on: June 15, 2020, 03:54:26 AM »
Are all lights LED? What did you have to change from stock to allow LED's to cope with the power? Have any fuses blown? If it is a short one of the fuses in the battery bay would generally blow.
Jp6940
« Reply #2 on: June 16, 2020, 03:52:51 AM »
I changed out front and rear blinkers with led’s.  The headlight was led as well.  No issues for the past year.  All were working fine.
The odd thing was when I hit the brakes the led’s would speed up their blinking.  Is that because there was a greater load?
No blown fuses.  Now when I put the blinkers on it seems like there is a very small amount of current bleeding through and all led blinkers barely light up.
Strange.
I was using the same stock relay for a few years without an issue.  What finally gave up?
TBR125
« Reply #3 on: June 16, 2020, 05:03:11 AM »
I am not familiar with using LED's but I do know that mixing systems can be troublesome, ie. standard relays with LED's vise versa. To solve any problem one needs to separate issues. If you have the original winkers for instance you could install them and see if problems persist.
Sorry I can't offer any other help.
