Author Topic: Hlw i replace the gas throttle?  (Read 436 times)
Yoni159
« on: June 18, 2020, 12:47:00 PM »
I have new gas throttle .. how i changed it? I see some cables go to the throttle body.. anybody know?
Re: Hlw i replace the gas throttle?
« Reply #1 on: June 18, 2020, 01:13:02 PM »
You mean you have a new throttle "handgrip" where you twist with your right hand?
Loosen all throttle cable adjustments, split switch block next to throttle grip by removing two screws, slide off old grip, slide on new grip, reattach two throttle cables, reassemble swith block, adjust cable adjustments so there is about 1/8th inch turn before throttle body butterfly starts opening.
Yoni159
« Reply #2 on: June 21, 2020, 01:35:38 PM »
Sound difficult and dangerous if i am dont know how to do it right
