Author Topic: gear oil parts  (Read 750 times)
mnpugdog
gear oil parts
« on: June 21, 2020, 08:06:14 PM »
Maybe I'm just missing it when I look online but I can't find it. I'm looking for the gear oil filler bolt. Mine will not tighten all the way. I looked online at all the diagrams but for some reason can't find it. Anyone have any idea what the part number is so I can order one?
Re: gear oil parts
« Reply #1 on: June 21, 2020, 08:10:05 PM »
Whoa! "Won't tighten all the way" means what?
Re: gear oil parts
« Reply #2 on: June 21, 2020, 08:45:07 PM »
The "S" word, I'm afraid.
mnpugdog
Re: gear oil parts
« Reply #3 on: June 21, 2020, 09:26:29 PM »
meaning in the 8  years I have done this it will not snug up to the hole. I only tighten to the specified torque .but for some reason this time  it won't. It came off easy like always and went in by hand just fine but when I went to tighnten it it doesn't want to to. And I didn't want to try any more because I didn't want to strip anything.
Re: gear oil parts
« Reply #4 on: June 21, 2020, 09:45:20 PM »
Well, it likely is not that the bolt has stripped...but it being of softer metal, more likely that the case is getting stripped.
Other than rethreading the hole and using a larger bolt....have heard that a fibre gasket can work to stop gear case leaks when used with a carefully tightened bolt in a nearly stripped case.
Not a permanent fix....but.
Re: gear oil parts
« Reply #5 on: June 21, 2020, 11:57:38 PM »
Yes, close inspection will undoubtedly reveal stripped threads in the softer aluminum like Stig said. Magnifying glass, a powerful flashlight and a knee pad ought to do it. You may be able to do the washer thing Stig mentioned but I will bet you will have to rethread very carefully.
mnpugdog
Re: gear oil parts
« Reply #6 on: June 23, 2020, 01:09:58 AM »
thanks guys, I was afraid of that. I've always tried to be careful but I know it can still happen with the aluminum vs a steal bolt. I guess the one plus is that it's the filler hole and not the drain hole. LOL
