Did you miss your
activation email
Technical | How To
Pilot Jet Size for Pod Filter
Topic: Pilot Jet Size for Pod Filter (Read 273 times)
Chris0381
July 01, 2020, 01:26:40 PM »
I want to give a pod filter a try, and the stock pilot/idle jet is #35.
Its been mentioned I should go 1 to 2 sizes up on the idle jet.
The next size available is #38
https://jetsrus.com/carburetor/carb_keihin_PB_carb_parts.html
So that would be 3 sizes up or 1 size up.
Thanks
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
eamartin
Re: Pilot Jet Size for Pod Filter
July 01, 2020, 04:46:51 PM »
Most of the assortments I see for sale come in 32, 35, 38, 40, 42, 45 and up. So I expect that the next size up for you will be the 38.
souzamoto
Sr. Member
July 01, 2020, 05:24:11 PM »
Different jet brands use different size systems
But, if you can get a 38 ithink that would be fine. Then you can fine tune with the mixture screw.
With a Pod, you may also have to increase the Main Jet a size or two.
Back
