Author Topic: Kymco 450 nothing happening after hitting starter button  (Read 480 times)
dmgoff
« on: July 03, 2020, 12:06:01 AM »
After I turn the key on everything on the dash lights up but as soon as I hit the starter button everything goes out...any help appreciated
Re: Kymco 450 nothing happening after hitting starter button
« Reply #1 on: July 03, 2020, 12:34:48 AM »
Bad connection or battery.
pa-outdoorsman
  • Pennsylvania
« Reply #2 on: July 03, 2020, 03:34:05 PM »
You've got a short in the wire, or maybe a blown fuse? Since everything that is supposed to happen immediately prior to starting seems to be happening, there has to be something cutting power from the system as soon as you press that button. I guess that's obvious, but it can only be so many things.
If there's any good news here, my guess is that it's just an electrical issue and not some major mechanical flaw with your machine.
2018 Kymco UXV 450i
2021 Honda ADV 150
« Reply #3 on: July 03, 2020, 09:11:40 PM »
I would check your battery connection sounds like not tight or dirty terminal.
mousejunks
« Reply #4 on: July 05, 2020, 04:59:06 AM »
A weak battery can do this. Check all connections. Replace if necessary.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
« Reply #5 on: July 05, 2020, 02:44:18 PM »
link to good scooter video on diagnosing a no start using electric starter..should be same for UTV/side by side, etc.
