Author Topic: 1st belt & roller change on my Liberty150i 10,000Km  (Read 1863 times)
« on: July 07, 2020, 02:52:49 PM »
10,000 Km service....yesterday, hot & humid.
Piaggio has made some 900,000 of these Libertys over the past 20 years....so I follow their service schedule.
After my 1st experience with the 1st service & the VERY stuck belt cover on my LIKE200i years ago - I was NOT looking forward to this job.... what a pleasant surprise!
Parts used: belt, rollers, slide pieces and 2 new nuts. All OEM & stock. About $65. Started riding this "2018" scooter the summer of 2017. So, other than oil, gas  & filters - first new servicing parts.
Difficulty of job: pretty easy!
Tools: a torx screwdriver, 19mm socket, 8mm T-handle, bar-torque wrench, Sear's 1/2" li-ion impact gun, 3 dabs of hi temp grease.
Trickiest bit: using the Buzzetti hold tool
Rear holding tool….
No drama. cover came right off.
Filth under the belt cover: much less than my LIKE200i
Wear on parts: clutch pads barely worn (will measure belt and rollers later today - I was too hot yesterday)
Spent 2 hrs cleaning things.
Lubed 2 belt cover locating pins and the needle bearings on the rear of clutch.
Lots of discussion on getting more whiz-bang using different rollers - but I like he way my Liberty performs. So, stayed with stock parts.
Out for a nice coffee run this morning.
« Last Edit: July 07, 2020, 03:13:13 PM by Stig / Major Tom »
TBR125
  • East Tennessee, USA
Re: 1st belt & roller change on my Liberty150i 10,000Km
« Reply #1 on: July 07, 2020, 03:35:38 PM »
Can't believe that's what a scoot can look like at 10,000Km. Great work.
I lost a belt yesterday. The manual definitely made an error with the stated 16mm minimum service width. Mine vaporized at 19.2mm. What worries me is the belt is supposedly 20mm new.
« Reply #2 on: July 07, 2020, 03:41:34 PM »
On belt----OEM? how many miles? how old?
On Piaggio belts maint.=too often for 30,000 miles a year rider!! Rubber Band drive scooter should have drive system that is good for 50,000  miles or so!!  Otherwise cheaper to have small car.
« Reply #3 on: July 07, 2020, 03:50:08 PM »
Kymco belt?
TBR125
« Reply #4 on: July 07, 2020, 05:24:03 PM »
2nd OEM Kymco belt, and died at 12,630km. The first I changed at the recommended 10,000km before I got the manual with the width specs. Honestly I was impressed that any belt would last that long with the conditions I have ridden it in. It's not rated for unusual use such as trailers so I can't complain. I think it was heat from 2hr riding stretches that cause the rubber to separate at the nylon.
It was 4 years old.
« Reply #5 on: July 07, 2020, 05:46:36 PM »
An error in the manual? Please say it ain't so! Har, har! Belts are made by other companies and they usually have some pretty good data like minimum width on their stuff and competitors stuff. But somewhere between Engineering and tech writers/translators the info is "modified" with no proof reading.
For Major Tom: nice job! You coughed up for special tools, dincha! Probably the best thing since that front pulley configuration demands it!
scooterfan
« Reply #6 on: July 07, 2020, 06:23:58 PM »
Quite soon after I bought my Agility at 8500km I took measurements of the belt and it was about 18mm. I am not sure about the current measurement, but the current km reading is almost 24 000km. Same belt, about 11 years old.
@ Stig.
I noticed the Liberty’s oil sump seem to have cooling fins and the sump also seem to be a bit bigger than the sumps on similar sized scooters. I assume the Liberty takes more engine oil compared to the Like ?
« Last Edit: July 07, 2020, 06:33:54 PM by scooterfan »
« Reply #7 on: July 07, 2020, 08:10:34 PM »
@ Stig.
Good eye!
Yes a little over 1/2 Qt more. Need 3 Qts to do 2 oil changes - LIKE takes less than a Qt.
3 Qts will get you 3 oil changes with a LIKE...and some spillage :-)
Liberty also has a spin on filter and a screen.
Wish it had the gear oil dipstick which a lot of Piaggios have. (Vespa guys told me I was stupid for not being able to locate it! Owning a Liberty on the Vespa forum is akin to owning a Beetle on the Porsche forum)
« Last Edit: July 07, 2020, 08:42:20 PM by Stig / Major Tom »
« Reply #8 on: July 07, 2020, 08:46:14 PM »
Did anyone notice the one LIKE200i part on the Liberty?
Piaggio gave these scoots a 2" puke tube - with a sealed tip.
I spent a couple of hours fitting a much longer tube from a box of LIKE spares I bought on ebay yrs ago.
It was heck to reach.
I opened the cap yesterday while working on the CVT, tablespoon of stuff came out.
« Reply #9 on: July 07, 2020, 08:52:12 PM »
Piaggio Dealer
"Looks like we've lost J.G. as a Liberty customer."
"Yep."
"Want a Pepsi?"
« Reply #10 on: July 08, 2020, 01:54:08 PM »
wait, you have a scooter that allows you to remove the cvt cover without disassembling half the bike?  :D
Brilliant!
(to get to the cvt cover I have remove all this)
« Reply #11 on: July 08, 2020, 04:57:08 PM »
Brilliant!
That's a great looking scooter....but I hope you're joking!?
Before I bought this Liberty - my 4th & I hope my final scooter, I spent $8 on a service manual download.
THIS time I was looking for easy valves, easy CVT, easy muffler, easy shock mounts....and easy brake fluid reservoirs.
Well, I got all but the easy to access brake reservoir.
Since I do all DIY, and at my age - as much as I love fooling with a scooter - I'm a lot more friendly to, and considerate of,  my body!
If it is a pain to work on, I'll just end up being unfaithful to it - and will start an emotional affair with another red scooter (probably a Honda) - because I'm too cheap to send it out for service.
« Reply #12 on: July 08, 2020, 05:45:19 PM »
Stig, I wish I was joking! The left 4 inches or so of the cvt cover are covered by the plastic bodywork...no way to remove it without pulling off the plastics (seat/ bucket, rack, fender and body tub). Luckily I've got it down to about 10 minutes from the hour + it originally took me.
Wish all scoots were designed with a little panel to expose the spark plug and valve cover, an easily accessible cvt cover and brake fluid reservoirs!
Your Piaggio is rocking all Vespa mechanicals, right? The 150cc engine and driveline are lifted straight out of a Vesap? (or the vespa's are lifted straight out of a Piaggio?)  :D
« Reply #13 on: July 08, 2020, 10:32:52 PM »
I don't know enough about Vespas to answer that …..but this 155cc 3 Valve i-Get engines are in some Vespas I'm told.
I was surprised to see a kick start on your scooter. A genuine 200 cc engine , or a 163?
« Reply #14 on: July 09, 2020, 12:05:14 AM »
163cc, just like your Like, only with a carb.
