Author Topic: Stock exhaust question  (Read 985 times)
Cypher1982
« on: July 16, 2020, 08:07:25 PM »
Hey guys, I have a 50 but had some curious things. I was hoping someone with a stock exhaust laying around may be able to do some looking for me. Also could use someone who doesnt mine turning a few wrenches for the say of learning lol.
TBR125
  • East Tennessee, USA
Re: Stock exhaust question
« Reply #1 on: July 16, 2020, 08:10:02 PM »
I am available until tomorrow. What do you need?
Cypher1982
« Reply #2 on: July 16, 2020, 08:23:41 PM »
Awesome and thank you! Well from what I can see most parts are interchangeable. I was curious on the stock exhaust, what its bore is coming from the engine and the outlet tail pipe. I just had some curious thoughts wondering if the 125 stock exhaust could end up being used as a sort of upgrade for us smaller 50 guys.  Alsp probably wouldnt hurt to have a picture/measurement of head mounting flange and bolts. Haha sorry I'm needy. Still trying to get mine back to pulling well again. But she can do over 40mph gps verified and filled up last night and calculated 96mpg
JJJoseph
  • Kymco Sento
« Reply #3 on: July 16, 2020, 09:47:34 PM »
No the 125 parts won't fit.  Other than that, most 50cc exhausts share the same flange profile at the cylinder head, but the rest of the bolt holes don't always line up, requiring some custom fitting and welding.  Sometimes it's worth the effort, but not always.
TBR125
« Reply #4 on: July 16, 2020, 10:45:04 PM »
The exhaust manifold end of the pipe is .75inch OD. I would be concerned about the mounting bolt positions as I don't know about the 50cc crank case design.
Cypher1982
« Reply #5 on: July 17, 2020, 12:57:23 AM »
Well a grinder and welder and skills I have, I figured its gotta flow better than the 50cc unit, plus it would look stock and probably be a lot quieter. I dont want to open my can and hollow it out...I do t want it raspy or loud and obnoxious, but a quiet better flowing nice looking muffler would be nice
Guess I should put my reasoning out there also. I had my stock unit off the other day, and realized it's got to be VERY close to the 125 unit because of frame sizing and locations etc. But the 50xx unit is a double wall pipe and its very small internally
TBR125
« Reply #6 on: July 17, 2020, 01:12:08 AM »
If it's double walled then the 125 might fit. Feel free to guinea pig it for us all as the info will be useful to someone. Good luck.
A welder is a step ahead of the cold bend bar stock mounts I've got.
JJJoseph
  • Kymco Sento
« Reply #7 on: July 17, 2020, 02:47:04 AM »
LOL! Nothing on a Kymco, nor in the steel market, is in "inches"!! Press the button on your vernier caliper so we're talking the same language :-)
TBR125
« Reply #8 on: July 17, 2020, 11:58:58 AM »
Ha! My eagle eye reads American inches only. It is actual 3/4 pipe but if you prefer 19mm your welcome:)
Cypher1982
« Reply #9 on: July 17, 2020, 01:02:53 PM »
Lol. Well played gentlemen (general assumption, dont hate me) any chances we can get internal measurements? Lol
TBR125
« Reply #10 on: July 17, 2020, 01:46:48 PM »
3/4 - 1/16 times two walls would be 5/8 inch. Google says that's 15.875mm ID.
Cypher1982
« Reply #11 on: July 17, 2020, 03:45:18 PM »
Awesome. So I'll drop mine and measure it. IF they were somehow the same part... I'd say that would rule out the need for an aftermarket pipe for the 50s wouldnt yoi?
JJJoseph
  • Kymco Sento
« Reply #12 on: July 20, 2020, 04:43:43 PM »
Guys, do us a favor: steel is not measured in "inches" and converting it makes it worse as you can see.  Nobody makes steel tubing in "inches" any more. Stick with the proper units, it's not rocket science!  Thanks :-)
TBR125
« Reply #13 on: July 26, 2020, 09:55:28 PM »
I haven't purchased a new caliper and my draft set only reads inches. I apologize for my inability to accommodate.
