Author Topic: Starting issues  (Read 2026 times)
Jono21
Starting issues
« on: July 29, 2020, 12:48:59 PM »
I have a 2009 super 8 150 I put in a new carb because the old one went bad. I got it idling well and it has good rpm.
The problem is when it sits it takes a while to get started like 10-30 sec holding down the start button.  It will run and drive great and start right up after that but if it sits for a couple hours its hard to start again.
Any ideas?
Thank you.
Re: Starting issues
« Reply #1 on: July 29, 2020, 12:59:47 PM »
so it doesn't start easily when cold?...but runs fine otherwise?...the auto bystarter may not be working properly
Jono21
Re: Starting issues
« Reply #2 on: July 29, 2020, 01:06:42 PM »
Yes runs quite well once I get it warmed up.  Is that different than the autochoke which is also new with the carb.
Jono21
Re: Starting issues
« Reply #3 on: July 29, 2020, 01:11:07 PM »
How can I test it to see if its working?
Re: Starting issues
« Reply #4 on: July 29, 2020, 01:19:15 PM »
I think the basic test is to remove it from the carb, measure how far the needle is protruding, add 12V power to it and after a few minutes it warms up and the needle should extend a bit.
i'd do an internet search on 'how to test an auto bystarter' and you should get a ton of hits...OK, I just did and lots of results pop up.
Something else you could do is swap out the bystarter from your old carb to see if that one works with your new carb.
Jono21
Re: Starting issues
« Reply #5 on: July 29, 2020, 02:10:11 PM »
Ok thank you ill give it a try. Should I also try a valve adjustment? I did one last season.
Jono21
Re: Starting issues
« Reply #6 on: July 29, 2020, 05:09:19 PM »
I am going to try your suggestions tonight but from doing some research I saw someone noticed that his kymco super 8 was wired backwards from factory so he had to switch the wires around on the auto choke im thinking that could also be my issue? Most scooters are AC and mine is DC so maybe the auto choke is wired up for ac if that is even a thing lol?
Re: Starting issues
« Reply #7 on: July 29, 2020, 05:56:25 PM »
not sure about the wiring of the auto choke...but yes, valve adjustment is another thing to look for when you have hard starting. Sounds like you have the skills to get this figured out. Usually just a matter of determining what could be the causes and eliminating those one by one.
Be sure to let us know how this turns out!
Re: Starting issues
« Reply #8 on: July 29, 2020, 09:40:46 PM »
You may have the CDI (Capacitive Discharge Ignition) confused with the auto bystarter. CDI can be either AC or DC. Auto bystarter is just a heating element device so not picky about type of current as far as is practical. I think there is no polarity involved so not likely to be hooked up backwards. There IS a resistor in that circuit that most don't think about. The auto bystarter will not work if that resistor is open.
Jono21
Re: Starting issues
« Reply #9 on: July 30, 2020, 01:16:36 PM »
Ok guys problem is solved upon further investigation I found two missing vacuum lines so now I need to find out if they were missing before I got the new carb or if they took them off and didn't put them back im surprised it was running so good once it started lol.
scooterfan
Re: Starting issues
« Reply #10 on: July 30, 2020, 04:58:57 PM »
Who actually installed this carburetor ? You initially mentioned “I put in a new carb” but in your last post you were referring to “they” .
Hopefully a scooter mechanic at a scooter shop was not responsible for such dodgy work ?
Kymco Agility 125
Honda Silverwing 600
Suzuki Boulevard C50T
Jono21
Re: Starting issues
« Reply #11 on: July 30, 2020, 06:55:06 PM »
Sorry for the confusion someone installed it for me its more of a side business he came recommended well but apparently not.  It's hard to find anyone to work on these things if there not a honda.  But I have learned a lot about my bike and feeling a lot more comfortable working on it now.
Plus you guys are loads of help!
