Author Topic: Transmission SAE90  (Read 851 times)
Dstewart73
Transmission SAE90
« on: July 31, 2020, 05:30:40 PM »
The owners manual For my 2007 Xciting 500 calls for SAE 90 for the transmission. I cannot find it at autoparts stores or online.
Is 75W90 an acceptable substitute?
Thank you,
Dana Stewart
TBR125
  • East Tennessee, USA
Re: Transmission SAE90
« Reply #1 on: July 31, 2020, 06:00:31 PM »
The 90 is the important part which is the thickness of the oil (please correct me lubricant gurus if I am mistaken) and the W is the operating temp range. I currently use Lucas 80W-90. 75W-90 is fine but I will see if I can find a good chart.
The manual simply states sae90 as the W will vary whether it is summer or winter etc.
« Last Edit: July 31, 2020, 06:02:17 PM by TBR125 »
Dstewart73
« Reply #2 on: August 01, 2020, 07:27:56 PM »
Thank you. I’ll try the 80W90.
Forbes1964
« Reply #3 on: August 07, 2020, 09:32:02 AM »
Actually both numbers are important. But your basic premise is correct. The W is the viscosity when tested at 0 degrees F. The other numbers is the viscosity when tested at 212 degrees F. So 75w-90 flows like 75 viscosity at 0 and like 90 viscosity oil at 212. .Bottom line, yes it can be used in place of 90 weight oil (or any oil between 75 and 90.)
2009 Xciting 250
