Author Topic: Transmission Oil  (Read 1617 times)
Dstewart73
Transmission Oil
« on: August 03, 2020, 10:46:25 PM »
When filling the transmission oil do you fill from the bottom drain hole until oil comes out the actual fill hole?
I remember servicing the lower unit on an outboard that way. I think it will work, just not sure if it’s kosher.
Again, thanks in advance.
Dana Stewart
TBR125
  • East Tennessee, USA
Re: Transmission Oil
« Reply #1 on: August 03, 2020, 10:52:13 PM »
That is how I have done it and with no ill effects. As long as there is sufficient oil to keep the gears bathed, and not so much as to fill your air filter, you should be fine. Also, the manual states a volume(approx. 200ml in my case) for the gearbox. You can fill it until either the spec or fill hole is reached.
jeeves
  • Dubrovnik, Croatia
« Reply #2 on: August 04, 2020, 07:36:26 PM »
There's a reason why it's called a drain and filler hole.
Drain at the drain hole, fill it through the filler hole.
Agility City 125
« Reply #3 on: August 05, 2020, 12:42:19 AM »
Dana Stewart
I've changed all three of my 500'S transmission oil  that way without any issues.  I'm use to dealing with outboards as well.
leomagnus
  • Providence, RI
« Reply #4 on: August 05, 2020, 05:33:09 PM »
I use a big 50 ml drugstore syringe that I can inject measured amounts of transmission oil in the filler hole. It seems to work well with minimum effort and almost no spillage.
See link
https://www.cvs.com/shop/luer-lok-tip-syringe-prodid-179150
Rome, Italy
'97 Honda SH50
'98 Aprilia SR50
'01 Gilera Runner 180
'05 Honda SH150
Warwick, RI, USA
'12 Kymco People GTi 300
'18 Kymco Xciting 400i ABS
'22 Kymco AK550 ABS
wymple
« Reply #5 on: August 07, 2020, 01:04:41 PM »
Spec is about a pint, so that's what I put in. That's all that drained out as well. How much does it take to get up to the filler hole?
« Reply #6 on: August 07, 2020, 01:37:10 PM »
Kansas Kymco and I were discussing this in another thread...on some scoots (my S200, for sure) if you fill until it comes out the filler hole you've over filled it and the extra will get sucked into your airbox..not good.
Other scoots seem to work just fine using this method. Personally, I'd prefer to drain it and put in the correct, measured amount of oil your bike calls for. That may or may not fill it up to the fill hole.
« Reply #7 on: August 08, 2020, 02:54:10 PM »
Really scooter rear ends are not fussy---just enough oil fine.  I use drain for drain, filler for filler.
« Reply #8 on: August 08, 2020, 04:28:17 PM »
I should have mentioned that in my response.  Before you told me I didn't even realize it was vented to the air box. That's why I filled it like I do my outboards.
Dstewart73
« Reply #9 on: August 16, 2020, 03:43:22 PM »
You guys/gals are good. Your knowledge amazing. Thanks again.
Dana Stewart
