Author Topic: Front Brake Sqeaking  (Read 1516 times)
ScottNicol
« on: October 04, 2010, 07:20:26 PM »
Hello again! :)
My front brake whenever I pull it in and out of my drive and when I ride at low speed (< 10MPH), it will sqeak (really high pitch). I know it's the front brake as when I move it on its own (on the stand), it makes the noise. Do the brakes need bleeding or the calipers readjusting?
Cheers,
Scott!
omfgdotcodotuk
  • fookin quick gilera ice 50/70cc malossified ish
Re: Front Brake Sqeaking
« Reply #1 on: October 04, 2010, 08:22:40 PM »
to be honest i dont think theres anything wrong at all,you could try 1 of 2 things 1 changing your pads for after market ones 2 or you could also remove the pads that are in there and smear a lil copper grease (ON THE BACK SIDE OF PADS NOT BRAKING SURFACE) the key word here is a little,squeaks on front disk brakes tend to be vibration the grease will or should supress this.Let me know how it goes bud :) ps the grease worked for me ;)
Never ride faster than your guardian angel can fly ;)
ScottNicol
« Reply #2 on: October 04, 2010, 08:31:49 PM »
Cheers mate! I'll have another look tomorrow and get back to you. Is it possible to move the pads a mm away from the rotor or are they set?
Also, as a side note, I've checked the oil and cleaned the air box. Is there any other maintenance I should do?
omfgdotcodotuk
« Reply #3 on: October 04, 2010, 08:41:42 PM »
take the pads out and lightly grease the backs,then post again if you got issues ;)re maintainance your plug could do with a once over too bud and a genaral inpection of nuts and bolts as they tend to come lose :)
oswaldters
« Reply #4 on: October 04, 2010, 10:04:02 PM »
And don't forget to check those valve clearances.  If you haven't downloaded the agility service manual you should do so.
There are links to it posted on the site - just search service manuals.
« Reply #5 on: October 05, 2010, 01:15:38 AM »
Cheers mate!
..dude..you from th' land down under??
 ;D
..yours is a 2007, right...which i reckon you bought used...
..brake "squeal" is nothing much to worry about, as long as you're stopping ok...
..some pad compositions squeal more than other..
..now a..."grinding" noise should raise a bit of concern..
ScottNicol
« Reply #6 on: October 07, 2010, 02:29:35 PM »
I get a really unhealthy sound while breaking. It's hard to describe... I'll get the service manual and see what that has to say too.
Rianna
« Reply #7 on: October 07, 2010, 03:42:39 PM »
"Unhealthy"...how so? And do you mean you here a noise all the time, or only when you apply the brake?
johnuana
« Reply #8 on: October 07, 2010, 07:58:26 PM »
i have exactly the same thing :D front brake squeaks when i use it stopping at low speed. i don't think it's anything to be worried about ;D
..as long as you're stopping ok...
omfgdotcodotuk
« Reply #9 on: October 07, 2010, 08:29:04 PM »
it aint john ;)
Rianna
« Reply #10 on: October 07, 2010, 09:05:12 PM »
Yeah...squeaks...I read "unhealthy" and thought maybe he meant a different or new type of noise...
« Reply #11 on: October 07, 2010, 09:55:53 PM »
..it'll probably go away once you ride it for a few kms...
..especially if it's been setting for a while when you bought it...
