As recommended by all, a plug kit with co2 cart’s. I like the mushroom style but those require a special gun to install. If you do plug, I recommend replacing the tire ASAP. Most shops will not patch a tire, the liability is to great. If a shop will do the repair, I recommend a “plug-patch, which is a combo patch with a plug attached and requires the tire dismount
