Author Topic: No headlight and strange Reg/Rect values  (Read 463 times)
Sodster
« on: August 18, 2020, 08:50:56 PM »
Hi fellas!
I have this strange behaviour were the alternator is charging the battery and all probe points give correct voltages but I can't get the headlight to work.
Headlight is powered by the alternator so as not to drain the battery when the engine is shut off.
Lamps are new, regulator/rectifier is new and I measure 12VAC between two of the lamps terminals.
I've measured my regulator/rectifier with a multimeter and I get between 14 and 17 MOhm over the terminals stated in the diagram.
Has anyone any ideas what is happening here?
Cheers
Patrik
