Author Topic: Removing cover to replace headlight bulb  (Read 645 times)
jak51
  • Northeast Ohio
« on: August 19, 2020, 02:19:58 PM »
OK, here's a question that hopefully someone can answer.  How do you remove the front upper cover to access the healight bulb.  The directions in the Kymco manual shows how to remove it on the 2007 250 DINK, but it appears the GV 250 is configured a little differently.  Suggestions?  Thanks.
Jeff
