Duly noted.
Next thing I just can't figure out is why my gas tank floater will not display on my console cluster. I remove it from the gas tank the fuel gauge will appear. It's in the wire on the floater tube. Some how it's shorting out when I submerge. Is there a way to insulate that wire. There does look to be a some slits n the wire where the float tube rises. I can remove this arm but it's attached to a sensor on the EFI pump.
