Author Topic: Tach bounce?  (Read 572 times)
wymple
Tach bounce?
« on: September 04, 2020, 12:40:36 AM »
Cruising about 60mph, I saw my tach bounce a few times, clear up over 9K for a second or two. Is it on the way out? Common problem? Expensive fix? Xciting 500R, 2010 with 24K on it.
Lord Faversham
  • Upper Class Twit of the Year
  • Farkhem Hall, Tittering, Middle England
Re: Tach bounce?
« Reply #1 on: September 04, 2020, 07:53:21 AM »
I wouldn’t worry too much just yet. It could be a bit of moisture in the electrical connector behind the dash. Then again it could be a wire starting to break down between the headset and the coil (I think that’s where the tacho gets it’s feed from)
Whilst it’s working generally ok, on a scoot of that age I wouldn’t fret as you’re likely going to get a few foibles.
I have an intermittent issue with the left hand bulb on my instrument binnacle deciding whether it wants to work or not. I’ll deal with it next time I have the cowl off.  I’d recommend you adopt a similar approach and when next you have occasion to whip your cowl off, have the instrument connector  off and give it a good squirt of WD or Wurth.
If it’s sporadic, diagnosis is going to be difficult as the Law of Sodde will probably guarantee that if you get a multimeter on the wiring, all will be appear fine.
If it ain’t broke don’t fix it or you’ll fix it ‘til it’s broke.
Regards
Faversham
Farkhem Hall, Tittering, Middle England.
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Honda RD03 Africa Twin 750
Kawasaki GPZ500s
Derbi Terra Adventure 125
Countless Lambrettas
Re: Tach bounce?
« Reply #2 on: September 04, 2020, 11:36:47 AM »
Loose connection at battery in my case with a Yager...
wymple
Re: Tach bounce?
« Reply #3 on: September 04, 2020, 01:03:39 PM »
Thanks, guys. I just thought it was weird that the tach reading jumped to the high side. If it quit entirely I would be a while getting in there. My speedo tells me everything, anyway.
