Author Topic: Idle speed  (Read 1890 times)
wymple
Idle speed
« on: September 12, 2020, 01:09:06 AM »
I think my 500 idles a hair too slow, not far from killing out (IMO). Does the throttle have any adjustment or is it not to be messed with like a lot of FI engines?
Re: Idle speed
« Reply #1 on: September 12, 2020, 03:20:28 AM »
check the rubber air hoses may be clogged or leaking air ,. or   you could find a dealer with a diagnostic tool and a Meck.,  with a computer to adjust the throttle
Lord Faversham
  • Upper Class Twit of the Year
  • Farkhem Hall, Tittering, Middle England
Re: Idle speed
« Reply #2 on: September 13, 2020, 10:10:47 AM »
What rpm does the tacho show Wymple?
Regards
Faversham
Farkhem Hall, Tittering, Middle England.
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Honda RD03 Africa Twin 750
Kawasaki GPZ500s
Derbi Terra Adventure 125
Countless Lambrettas
wymple
Re: Idle speed
« Reply #3 on: September 14, 2020, 01:51:38 AM »
Fully warmed up it tops out about 700, as low as 500 for awhile.
Lord Faversham
Idle speed
« Reply #4 on: September 14, 2020, 03:10:55 AM »
Yes that is too low - about half what it should be.
You could try resetting the TPS and Idle Speed Controller. The ISC has a motor inside, which controls the air bypass valve to obtain a smooth idling speed. The ECU may record the incorrect ISC position when the engine is running for a number of reasons. It can cause the engine to stop, be hard to start or rough idling.
The procedure for doing so is as follows:
1. Put the side stand up and engine stop switch is at “RUN”.
2. Turn the key to the “OFF” position.
3. Fully open the throttle.
4. Turn the key to the “ON” position.
5. Release the throttle after waiting for eight seconds.
6. Turn the key to the “OFF” position.
7. Turn the key to the “ON” position.
8. TPS and ISC have been reset successfully.
If the procedure fails, repeat the steps from 1 to 8.
Might be worth a shot.
« Last Edit: September 14, 2020, 03:12:28 AM by Lord Faversham »
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
wymple
Re: Idle speed
« Reply #5 on: September 14, 2020, 04:15:11 AM »
Thank you! I thought I saw something kinda that way on you tube but it was unclear what they were doing in a foreign language.
wymple
Re: Idle speed
« Reply #6 on: September 14, 2020, 04:29:05 AM »
Well, that worked! I picked up a good 5-600 rpm! Much nicer now.
Lord Faversham
Re: Idle speed
« Reply #7 on: September 14, 2020, 10:50:49 AM »
Excellent!  Glad to have been of help. The book idle speed is 1400rpm but frankly that sounds far too high to my ear. Mine ticks over at around 1100rpm which sounds about right to me (which is fortunate!!). So if yours is in the same parish it’s all good.
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
wymple
Re: Idle speed
« Reply #8 on: September 14, 2020, 06:54:32 PM »
Mine is now idling round 1000-1100 rpm now, cold or hot.
Lord Faversham
Re: Idle speed
« Reply #9 on: September 14, 2020, 09:32:37 PM »
Spot on!
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
Re: Idle speed
« Reply #10 on: September 15, 2020, 06:15:03 AM »
Spot on!
Very useful information, well done ole chap.
wymple
Re: Idle speed
« Reply #11 on: September 19, 2020, 03:01:05 AM »
A bit of an update. Since resetting the idle my cold start problem is gone! I don't know if it's because my earlier efforts on cold starting cured it or the idle speed fix did. But it starts right up now without the throttle twist trick.
Lord Faversham
Idle speed
« Reply #12 on: September 19, 2020, 07:56:05 AM »
The idle speed fix resets the throttle body. It clearly wasn’t opening far enough on tickover so it will have reset the baseline throttle position too. I suspect that by opening the throttle fully before switching on, you effectively would have physically moved the throttle into a position where it was open sufficiently.
All good news either way. [emoji106]
« Last Edit: September 20, 2020, 04:57:01 AM by Lord Faversham »
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
wymple
Re: Idle speed
« Reply #13 on: September 19, 2020, 06:27:35 PM »
It would be difficult to explain how much I like this thing. The bigger bikes aren't getting much action.
Lord Faversham
Re: Idle speed
« Reply #14 on: September 20, 2020, 04:52:44 AM »
I’m much the same. I used to ride my bigger bikes through necessity rather than for fun but I’m out for a ride on my scoot most evenings purely for pleasure.
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
