Author Topic: You have a flat tire - now what?  (Read 261 times)
« on: September 21, 2020, 02:51:46 PM »
Very briefly - every rider should carry a flat tire patch kit and a means to inflate the tire.
Even if you have a cell phone and a roadside recovery system in place, and even if your plan is to replace every flat tire with a new tire - there might be a time and place when you'll need to fix your own tire in order to get down the road to a safer place to stop.
The kits are small, and not that expensive - especially when compared to the price of a tow.
Shop Revzilla (or others) for patch kits and tire inflators.  AND - make certain you carry a pair of pliers to remove whatever is stuck in your tire!
Is It Okay To Plug a Tubeless Motorcycle Tire?
HOW TO REPAIR A TUBELESS TIRE
I have had a flat tire 3 times, on 3 different scooters, while out on the road - my roadside repair and inflator kits got me home twice.
« Last Edit: September 21, 2020, 02:53:28 PM by Stig / Major Tom »
big blue
Re: You have a flat tire - now what?
« Reply #1 on: September 21, 2020, 05:00:02 PM »
I had a flat in the front tire of my Like in the first 6 months of ownership. Luckily it was discovered in my driveway so no tow necessary. I used my patch kit and refilled the tire and that tire is still in use at 11000 miles. I do have roadside and towing though just in case.  ;)
« Reply #2 on: September 21, 2020, 05:06:31 PM »
Sound advice Stig.
