Author Topic: People S200 rear wheel removal and rear brake shoe replacement  (Read 10497 times)
brianmckewen
Re: People S200 rear wheel removal and rear brake shoe replacement
« Reply #15 on: March 18, 2021, 07:07:55 PM »
Did not realize tub had to be off to get to cvt cover. I have new set of weights, Sliders, I like them on my helix, so will try them here. I will inspect belt but will probably buy new one and replace so I don't have to worry about that for a while. I got the wrong size weights. I ordered 14 gram instead of 13 but I don't think this will change performance much and I am not much of a "sport" rider. I just like to putt around and smile. Thanks again. Brian.
2009 Kymco People S200
2022 Honda Navi
2022 Honda ADV 150
Tromper
  • Seattlish
« Reply #16 on: March 19, 2021, 03:41:25 AM »
As I recall if you leave one bolt off or drill one hole and add a removable cover for it (metal or plastic, available at hardware stores usually) you could remove that without taking the cover off.  I sold mine before I made the mod, but I did give it some serious though and probably would have drilled the hole if I'd kept it longer.
Far as sliders.  I'd go one gram down from stock weight.  I had the OEM weight for the slider and it killed the flat spot but I still thought just a bit more in the lower end would have been nice.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
« Reply #17 on: March 19, 2021, 11:28:01 AM »
@lahawk,
just saw your documentation right now, GREAT!!
This is really something useful, again compliment!
