Author Topic: 2018 Kymco Like 150i headlight replacement bulb  (Read 1097 times)
rsgree
« on: September 22, 2020, 07:09:54 PM »
Hey, new to the forum and have a 2018 Kymco Like 150i as noted in the subject.  I have an issue where the "normal" low beam headlight is out, but the high beam is working, so it appears that I need to replace the bulb.  I have a shop that does work on scooters but they want me to purchase the bulb (I'm not comfortable taking apart the front/rear cover to get at the bulb) and then they'll do the replacement.  I don't mind paying for it as I have some other stuff I want to get checked out at the same time.
Can someone point me to an Amazon link/listing for a replacement bulb that is known to be the correct replacement?  I can't find any specifications on the bulb itself -- most places just say to pull it and then match it ...
JJJoseph
  • Kymco Sento
Re: 2018 Kymco Like 150i headlight replacement bulb
« Reply #1 on: September 23, 2020, 06:12:13 AM »
That's what I do - never had any problems.
« Reply #2 on: September 23, 2020, 01:23:18 PM »
you may be able to look through your headlight lens at the bulb and see writing on the bulb base. On my S200 I can see the bulb says Philips HS1 35W/35W. Very small writing. I've attached a closeup pic
« Reply #3 on: September 23, 2020, 06:53:07 PM »
Get the correct bulb from your Kymco dealer.  Refer to shop manual or maybe even owner's manual for instructions.
rsgree
« Reply #4 on: September 23, 2020, 11:12:20 PM »
Thanks for all the replies!  The dealer I had been going through has pretty much shutdown (not answering the phone, not responding to e-mails, etc) because of Covid, etc, but I managed to finally find another local place to get parts.  It's a bit of a drive, but at least I can get the parts I need (which seems to be more and more of a struggle these days ...)
« Reply #5 on: September 24, 2020, 11:16:13 AM »
If you know the bulb specs, seems like NAPA or other auto parts store could get you one?
JJJoseph
  • Kymco Sento
« Reply #6 on: February 22, 2021, 08:16:45 AM »
Right - all Kymco bulbs are standard auto parts, and any reasonable auto parts shop has them.
