Author Topic: How can I vent my gas cap?  (Read 1088 times)
gringostar
« on: September 26, 2020, 04:52:50 AM »
Hello,
My Agility 125 goes for about 15 miles and then it dies.  If I open up the gas cap it runs great.  If I run it without a gas cap it runs great. Clearly the gas cap is not vented.  How can I remedy that?  I don't want to spend $30 for a new gas cap.  I may go to Lowes or HD and buy a vented gas cap for a lawn mower. But, that will cost $10+ USD.  Can I drill it out?  Got videos?  Links?  Pics?  Thank you from El Paso, TX.
Re: How can I vent my gas cap?
« Reply #1 on: September 26, 2020, 11:16:37 AM »
I think you can drill a small hole in the cap....but you'll have to turn yourself in to the EPA.
« Reply #2 on: September 26, 2020, 11:55:43 AM »
Very small hole, no bigger than 1/16" will do. You will have to study the cap carefully. I cannot recall how the Agility cap appears.
The problem is caused by the vent valve sticking closed.
« Reply #3 on: September 26, 2020, 06:37:40 PM »
Also, good idea to remove cap from tank before drilling. (Legal Team added this)
« Reply #4 on: September 26, 2020, 10:29:58 PM »
Stig gets it! Remove cap! Har, har!
Vision
« Reply #5 on: September 28, 2020, 12:03:45 AM »
I believe there's a vent separate from the cap, a tube. Check that. Check the peacock. I wouldn't drill into the gas cap. Hit a bump and your butt can catch fire.
« Reply #6 on: September 28, 2020, 12:22:02 AM »
Yep, there is a tube. It goes to the vacuum operated vent valve that sticks shut andvstarves the engine of fuel. I have vented a Genuine Buddy 150, a Yager 200i and a Downtown 300i. The Buddy gas cap WAS under the seat but no burned butts!
