Author Topic: Got a new clutch  (Read 842 times)
Yoni159
Got a new clutch
« on: September 30, 2020, 05:27:06 AM »
Hi i got a new clutch but its seem they send me one pads broken... Can i still ride with it?
https://ibb.co/DRyD2Rk
Re: Got a new clutch
« Reply #1 on: September 30, 2020, 07:22:49 AM »
I’d personally return it for an exchange as it was at best damaged in transit and at worst failed even the most cursory of quality checks at the factory!
Yoni159
« Reply #2 on: September 30, 2020, 11:58:19 AM »
I dont have choice for this now. But i asked if its possible to ride with this? Or it could be bad
« Reply #3 on: September 30, 2020, 12:08:40 PM »
Bad. Get it replaced.
« Reply #4 on: September 30, 2020, 12:10:05 PM »
OK.  Interesting to see I'm not the only one of that opinion - thanks Karl!  Turning to that specific question however, I suspect the answer will be yes you could probably use it like that, but I'd await the opinion of someone more qualified than me to rule on it.  I am, at best, an amateur mechanic!
« Last Edit: September 30, 2020, 12:12:45 PM by Neil955i »
« Reply #5 on: September 30, 2020, 12:11:20 PM »
Seems he can't replace it Karl.  Can he use it without it screwing up his transmission?
« Reply #6 on: September 30, 2020, 01:10:50 PM »
The transmission will be okay but clutch and bell might not. Back in the brake shoe days even local shops could bond friction material to brake shoes....
Yoni159
« Reply #7 on: September 30, 2020, 07:01:25 PM »
Can I buy separately one clutch shoe and install it?
« Reply #8 on: September 30, 2020, 07:15:09 PM »
I finally saw the link and looked at your picture! Can the supplier take this as a returned item damaged in shipping (?) and replace it? You received it this way?
Yoni159
« Reply #9 on: September 30, 2020, 07:19:42 PM »
i bought it from very bad place they they customers service are awufal and i suspect they send me a broken clutch for purpose. Clutch cant brake in the box without have any broken piece inside... They scammers they also dont answer to emails... Very bad
scooterfan
« Reply #10 on: October 01, 2020, 12:21:58 AM »
I think in the longer term the damaged pad will get worn faster and eventually the clutch will be off-balance due to less weight on the one pad. This might shorten the lifespan of the clutch bearings - specially the needle bearing.
If the clutch did not come with a new bell and pulley, I think the needle bearing on the old pulley will be on it’s way out long before the new clutch pads are worn - specially due to an off-balanced problem eventually.
« Reply #11 on: October 01, 2020, 02:08:50 PM »
I think your point on balance is valid. How about weighing the damaged shoe and then removing material from the other two shoes in a similar place to equal? That way he could use them without balance vibrations.
« Reply #12 on: October 11, 2020, 10:05:01 PM »
looking at your picture just ride it , and check it every 10,000 miles
