Author Topic: Maintenance  (Read 858 times)
testerk
Maintenance
« on: October 08, 2020, 01:46:21 PM »
I am helping someone do maintenance on their 50.
Do these models have oil filters?
thanks
Re: Maintenance
« Reply #1 on: October 08, 2020, 01:52:09 PM »
« Last Edit: October 08, 2020, 01:57:13 PM by Neil955i »
Re: Maintenance
« Reply #2 on: October 08, 2020, 03:35:41 PM »
Just a strainer like Neil said. No filter.
testerk
Re: Maintenance
« Reply #3 on: October 08, 2020, 06:38:36 PM »
Thank you. So do  you just clean the screen instead of replacing it?
Any idea where I can find the items/parts that need to be replaced/cleaned during maintenance?
I've been trying to find info on fuel and air filters and the information I've come across isn't very consistent.
Is there an online seller that has the needed filters?
Re: Maintenance
« Reply #4 on: October 11, 2020, 04:50:14 PM »
Readily available on eBay in the UK, suspect it will be the same Stateside?
testerk
Re: Maintenance
« Reply #5 on: October 12, 2020, 12:08:10 PM »
I have seen the items for sale on ebay but shipping from UK can be expensive. The Kymco dealers in the U.S. that I have called don't even sell maintenance items.
Hiyaro
Re: Maintenance
« Reply #6 on: December 26, 2020, 11:17:53 PM »
Yes you clean it.
Unless it's completely dead, then you'll have to change it.
JJJoseph
  • Kymco Sento
Re: Maintenance
« Reply #7 on: February 23, 2021, 07:22:22 AM »
Nothing needs to be purchased (except a litre of oil).  Just clean the screen and replace.  Careful though: when you unscrew the drain plug, there's a spring inside and the screen & spring bits will fly apart.  Unscrew it carefully so you see how it goes back together.
