Author Topic: Dash Lights & Clock  (Read 3005 times)
Vision
Dash Lights & Clock
« on: October 23, 2020, 01:00:12 AM »
My dash lights went out and the clock stopped working. Anyone know of a tutorial on how to fix these? Don't see any youtube videos.
Re: Dash Lights & Clock
« Reply #1 on: October 23, 2020, 01:09:37 AM »
Wiring diagram.
Fuses.
Wiring connectors.
Grounding points.
What works and what does not?
Vision
« Reply #2 on: October 23, 2020, 01:23:06 AM »
The dash has gone completely dark and the clock hasn't been working for a year. I suspect the rectifier problem this summer blew out the dash lights. I don't know where to start other than taking random bolts off.
« Reply #3 on: October 23, 2020, 05:01:40 AM »
Random not good. Got to have a plan. Do you have a voltage tester or meter?
Vision
« Reply #4 on: October 23, 2020, 01:03:28 PM »
Yes
« Reply #5 on: October 23, 2020, 01:49:13 PM »
Next, google wiring diagram for that model and download owner's manual...
Vision
« Reply #6 on: October 23, 2020, 05:39:31 PM »
The owners manual doesn't cover it and the service manual isn't clear about it IMO.
« Reply #7 on: October 23, 2020, 08:42:47 PM »
Then the wiring diagram....
Vision
« Reply #8 on: October 23, 2020, 09:44:50 PM »
Not enough info. Hope to find something like this:
« Reply #9 on: October 23, 2020, 11:37:19 PM »
Vision
« Reply #10 on: May 30, 2021, 05:24:56 PM »
Looking at the wiring diagram, do I have this right? The dashboard only has 3 lights?
2 x 12v, 1.7w
1 x 12v, 3.4w
Are these two above, 194 lights?
https://www.amazon.com/s?k=194+led+bulb+amber&linkCode=sl2&linkId=b2d32077948181a127a0ab258b2eb4a3&tag=micbe04-20&ref=as_li_ss_tl
If you put a 12v 1.5w bulb into a 1.7w or 3.4w outlet I assume the bulb will burn out? How do you shop for the correct wattage? Don't see 1.7w or 3.4w bulbs.
« Last Edit: May 30, 2021, 07:27:59 PM by Vision »
« Reply #11 on: May 30, 2021, 07:42:57 PM »
@Vision, NO, those glassbulbs will, as long as they are 12 V rated, not burn out if you put 1,5 W instead 1,7 or 3,4 Ws. Only lights dimmer. You can take any from 1,2 until 3,2 Ws. Take what you can get from an AutoShop like Checkers or....
Vision
« Reply #12 on: May 30, 2021, 08:42:24 PM »
Thanks
Vision
« Reply #13 on: July 04, 2021, 11:44:56 PM »
Well, the 194 lights do not fit. The light on the left is a burned out OEM and on the right is a 194. Does anyone know what bulb is used for the dashboard?
Vision
« Reply #14 on: July 05, 2021, 12:35:20 AM »
The OEM light above is from #7 which may not be a dash light but a turn signal light.
