Author Topic: carb. info new with the zx50 need to know what the factery screw settings both  (Read 4232 times)
nut
I need to know factery setting for the 2 screws on the carb. I messd with them and I'm. new with scooters n mean.   an :'(t running right n ithink that's got a lot to do with it and how do I get it to stop running lean help real don't know much about my zx50 on a long run then up hill it almost cuts off have to let allway off gas the play wit it then it acts like it cools down in its fin e just when under lode imodifide the air box but fix air flow with tape to make port smaler it workd fin tell. Imess with carb.
..welcome to the forum nut!!
..stick around a minute..
..there's a cpl guys got some kick-ass zx's that hang out here...
peace
sidthesloth
  • Kymco ZX50
G'day nut, sorry to take so long to reply. The air/fuel mixture screw and idle speed screw don't affect your full throttle running, that sounds like you may be starving for fuel at high engine speed. For tis I would guess to check you vacuum line going to your petcock, check that the inline filter is clear and the screen in the petcock is clear.
To adjust the idle mixture screw, screw it right in, do not force it, just gently to the end of it's travel, then screw it out 1 full turn. From there adjust it until you get your highest idle speed and then turn it out 1/4 turn, once you have done that you can adjust the idle speed to your desired setting using the idle speed screw which is the larger of the two. If you increase the airflow through the engine, you will need to increase the fuel flow to suit. If you have reduced the air flow through taping up your airbox mod, you may have closed it off too much and may be flooding at full throttle.
sidthesloth
  • Kymco ZX50
I have been trying to get a pick of the carb from the manual, but the only way I could get it was to take a picture of the page.
If you don't have a service manual for your scoot, there is a link to a free download in the general section in the thread "links to service manuals".
sidthesloth
  • Kymco ZX50
Sorry, here's the pic.
thebatman
welcome to the forum nut.. on mine the oem specs were the mix screw is 1 to 1-1/4 out from bottom. the idle screw is around 2 turns out from the bottom, this will be more to YOUR taste.... im with sid.... take the tape off and open her up!.  ;D ;D ;)
"THE BAT"MAN...
Says:
