Hi guys,
I bought this year (2020) the new Kymco People 125 modell, called "Kymco New People S 125i ABS" and it's this model:
https://www.kymco.de/roller/125-150ccm/new-people-s-125i-abs/Now I am trying to remove the battery (due to Winter time) but I got completely stuck because Kymco has changed the location of the battery with this new model.
Where it was in the previous model below the foot rest and easy accessible by just removing some srews...
In the new 2020 model the battery is behind the front cover (or a part of it) and the manual doesn't tell much about how to access it - it has some low resolution B/W images and only explaining exactly this:
* Remove the screws (1) on the front cover.
* Remove the plastic clip (2).
* Remove the front cover.
Where as the first step seems quite reasonable and the srews could be found quite easily (they are placed on the side facing to the driver on the right side above the ignition and on the left side on the same location opposite) I just failed to do the second step.
I have no idea what this "plastic clip" is, nor where it is located exactly (the (2) is just pointing to somewhere below the right headlight - or not...? the photo has just very poor quality), nor how this "plastic clip" should be removed.
And for the third step there was even no photo to explain how to "remove the front cover"... I assume that with some reasonable force and pulling on the correct places you could remove it.
But because I could only do step 1 I was only trying if the cover would already move a little bit when pulling here and there - but nothing moved and I did not want to use too much force to not break any of these plastic parts...
So, can anybody please explain me what this "plastic clip" (2) in step 2 might be and where it is located exactly and how it can be rmoved?
And maybe also what step 3 actually means (where to pull / push ...)
Thanks for your help - appreciate it,
Lars
