Author Topic: Diagnostic software/ tool  (Read 5117 times)
JJJoseph
  • Kymco Sento
Re: Diagnostic software/ tool
« Reply #15 on: December 30, 2020, 04:57:42 AM »
Black wire 12 volts, green wire chassis and data ground, white with yellow stripe data.
Have you actually done this and made it work?  Do you have any photos?  Where did you find the connector(s) - both ends?  What software are you using to parse and display the data? Does the memory and the live data both come from the same wire? Are you reading stored codes, or a continuous feed? If you're reading stored codes, are you able to locate the code definitions?  Sorry for all the questions, but we have a near new Kymco 200i that will start but misfires and hasn't moved for over a year now, and it'd be so useful to figure out what's wrong.  I see over the last year that there's others here that also have the same problem.
Cambo
« Reply #16 on: December 30, 2020, 08:58:21 AM »
Thank you, I'll let you know how I get on.
« Reply #17 on: December 30, 2020, 01:59:54 PM »
No, I have not done this! This was the start of a project way back when the only "Kymco analyzer tool" was a wire harness and a PDA. You also had to load a program into the PDA to get it to work. Segue forward to today and there gotta be over ten apps that read OBDII codes with a phone! By the way, recently saw a precaution against blue tooth OBDII plugs that are cheap since they have corrupted codes or something.
Nope, no actual experience, just a bright idea! The wire colors are from the wiring diagram and that was verified on my DT300i.
« Reply #18 on: December 30, 2020, 02:50:29 PM »
Your "near new" 200i is out from under the 2 yr engine warranty?
JJJoseph
  • Kymco Sento
« Reply #19 on: December 30, 2020, 09:59:42 PM »
Yes it's a 2014 model (with only 6000km).  It's a really nice scoot otherwise.  Perfect for an old fart like myself to go shopping. There's no Kymco dealer within 100 miles so I can't count on any dealer support for anything :-(
