Author Topic: what is the size of the flywheel nut  (Read 1248 times)
B3N
« on: December 31, 2020, 12:01:22 AM »
I lost my nut  >:( so what is the size of the nut at the end of the crank shaft on the flywheel side uxv 500i 2012 thank you
Re: what is the size of the flywheel nut
« Reply #1 on: December 31, 2020, 08:01:40 PM »
You may not get many responses! I have  UXV500i and have never yet had a need to take the CVT apart.
B3N
« Reply #2 on: December 31, 2020, 08:31:07 PM »
i talk about the nut on the driver side where is the flywheel the nut is under the case for hand crank
« Reply #3 on: January 01, 2021, 12:22:12 AM »
I am sorry but I did not understand any of that. Also, I have not had to disassemble anything on the UXV.
CThacker
« Reply #4 on: October 18, 2022, 02:33:30 PM »
Where you able to figure out the size?  Send me a picture of your flywheel as I am about to open up the crank case to ensure my piston is at TDC.  I can tell you what the size it after that.
300winchester
« Reply #5 on: October 19, 2022, 11:32:07 AM »
Don't open up or take off side cover just to check to see if your piston at TDC, just take out the inspection plug, I sent you the manual and posted pics.  if you take that side cover off youll need a new gasket and your hours down with labor, if your after that 19mm socket nut, that on the side of the stator cover, there is a big allen that goes into in, its about a 3 " circle diameter, take that off you will see the nut, my flywheel had a sprag clutch on it, so only turn one way.
300winchester
« Reply #6 on: October 19, 2022, 11:38:03 AM »
https://www.manualslib.com/manual/2032784/Kymco-Uxv500i.html?page=818#manual
page 818
this manual will also show you what plug to take out to inpect for flywheel timing etc
300winchester
« Reply #7 on: October 19, 2022, 11:40:28 AM »
Nut size
Page 831
N.F.M14
