Author Topic: KYMCO UXV 450i Won’t start  (Read 1353 times)
Robdmillusa
« on: January 12, 2021, 03:08:33 AM »
When I try starting my Kymco 450 it makes a strange noise, the lights flash on the dashboard and I quickly see the LCD screen activate before it turns off. The UTV engine does not seem to be turning on. I know it has a full tank of gas. I have linked a video of what happens when I try to start it. Any suggestions on what is wrong and how to fix it?
https://drive.google.com/file/d/1Vjab-sE3nfpk9Q8i_jx6ouGFrRFm38rH/view?usp=drivesdk
Thanks,
Rob
airshot
Re: KYMCO UXV 450i Won’t start
« Reply #1 on: January 12, 2021, 03:19:40 AM »
Just listening to your video, battery sounds weak...these efi engines need a real strong battery to fire.  Check battery voltage, if not at least 12.4 volts then mabey try another battery.
Also check connections for corrosion as this can simulate a weak battery.  Good luck
« Reply #2 on: January 12, 2021, 09:21:29 AM »
battery
