Author Topic: ? Rev limiter  (Read 2119 times)
flying old guy
? Rev limiter
« on: January 14, 2021, 03:03:12 PM »
I have a 2012 Yeager GT 200i. When I bring it up to about 65mph, I'm touching the red line as seen on the tach. There is still more throttle to go but I start getting nervous about overrevving. I haven't felt like a rev limiter has kicked in, so wondering if there is one. Thanks, Ernie
Re: ? Rev limiter
« Reply #1 on: January 14, 2021, 06:40:38 PM »
On my downtown 300 2011, from break in to 20,000 Km.s   upon changing the rear tire while removing the exhaust ,  a washer dropped out the hole was 1/2 the size of the pipe, so must have been the RPM restrickor,  on my frost -Yager 2009 did not see anything on it ,  on my Piaggio B V 350 the manual says a electronic restrictor  cut in at 85 miles per hour,   going down hill I have passed 100 MPH and it did not drag it back with the motor  so it must cut off the torque at 85 MPH
CanuckFJ
Re: ? Rev limiter
« Reply #2 on: January 18, 2021, 08:45:36 PM »
Yes there is a rev limiter; cuts in at about 120kmph.  You will feel the power cut and see the engine light flash when it cuts in; usually with full throttle on a downhill stretch.
Kymco Yager GT200i
Triumph Trophy 900
Yamaha FJ1100
Yamaha FJ1200
Kawasaki KZ650
Delta, BC
flying old guy
Re: ? Rev limiter
« Reply #3 on: January 19, 2021, 06:38:48 PM »
Thanks for the reply. The other reason I ask, I have seen 70mph on the digital speedometer and it still felt like would still go a bit more. I've only did this once and most likely won't do it again.
Re: ? Rev limiter
« Reply #4 on: January 19, 2021, 08:10:21 PM »
  I have hit 115 Kmph,  well into the red about 8000 rpm never gone faster,  last time I tryed speeding the Reg., fried and had a hard time getting it going again,  went through 3 reg., before it would run again,.  ended with a downtown Reg., to make it go
