Author Topic: kymco brake fluid change  (Read 1415 times)
jasbos
« on: January 21, 2021, 06:58:29 PM »
hi just wondering what size tube I need to bleed the brake fluid as it needs replacing and is it dot 4 and does anyone know of a kit that works and know which 1 I should get
tks in advance oh its the large wheel agility i have think 16inch wheel
« Last Edit: January 21, 2021, 07:00:50 PM by jasbos »
Re: kymco brake fluid change
« Reply #1 on: January 21, 2021, 09:05:17 PM »
I purchased a hand vacuum pump from Harbor Freight that has a rezervoir for the old brake fliud. The kit comes with a short hose that will fit on the bleed valve. It helps if you have another person to fill the brake cylinder as you suck the old fluid out (you don't want to suck air into the system).  They have a electric model as well for more money but the hand pump works just fine.   Dot 4 or Dot 3 will just fine . Dot 4 has a higher boiling point and more money.
Make darn sure if you get ANY brake fluid on a painted surface you clean it off immediately or it will damage the paint.
« Last Edit: January 21, 2021, 09:12:31 PM by Kansas kymco »
jasbos
« Reply #2 on: January 21, 2021, 09:35:41 PM »
tks for that ill give it a go
« Reply #3 on: January 21, 2021, 11:27:44 PM »
if you're just looking for hose size it is a 3/16 diameter interior measurement. Vinyl tubing works great but doesn't hold up for long against brake fluid but is cheap and easily replaceable. You always want a very tight connection between bleeding hose and brake bleeder.
