Author Topic: Battery Charging: Downtown 300i  (Read 1621 times)
Mace3739
« on: February 23, 2021, 02:18:02 AM »
Hello everyone! My Downtown has what I think is a drained battery. I've got a trickle charger to charge it right up, but what tools do you think I'm gonna need to reach it? Any advice would mean a great deal to me.  ;D
mousejunks
Re: Battery Charging: Downtown 300i
« Reply #1 on: February 23, 2021, 04:30:39 AM »
Remove the seat - 2 hinge nuts + 1 strut nut
Remove the seat bucket - 4 nuts + 1 cable
Remove the battery cover - 4 screws
Easy and done.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
francuz69
« Reply #2 on: February 23, 2021, 07:44:07 AM »
By the way, all screws for seat and a bucket are 10mm, and all screws for battery cover are Phillips. So, very basic tools.
In my case for the seat, there are 2 hinge and 2 strut nuts. First undo strut, because then You can fully open the seat to undo the hinge.
Mace3739
« Reply #3 on: February 23, 2021, 03:11:26 PM »
Awesome, so all I'd need is a phillips and a 10mm screwdriver to access it and put it back together again?
Mace3739
« Reply #4 on: February 23, 2021, 03:12:01 PM »
Awesome, that does sound pretty easy.  ;D
« Reply #5 on: February 23, 2021, 03:19:51 PM »
A word of caution about trickle chargers.
When my Triumph battery completely discharged recently, the trickle chatter wouldn't even light up!  A few hours with a standard charger then I was able to switch over to the trickle charger successfully!  I'm sure someone on here will know why this might be.  I'm guessing the output from a TC is way too low to retrieve a totally dead battery!
Mace3739
« Reply #6 on: February 23, 2021, 03:53:49 PM »
Ah, I see. I also have a plug in wall charger. Perhaps I can get it started with that and then finish it off with the trickle.
« Last Edit: February 23, 2021, 04:12:37 PM by Mace3739 »
« Reply #7 on: February 23, 2021, 04:30:41 PM »
Yep, that's what I did!  Try the trickle first by all means, but it may not work right off...
pa-outdoorsman
  • Pennsylvania
« Reply #8 on: February 23, 2021, 05:54:22 PM »
I could be wrong, but he's probably talking about a 10mm socket.
2018 Kymco UXV 450i
2021 Honda ADV 150
Mace3739
« Reply #9 on: February 23, 2021, 06:07:54 PM »
I see, phillips screwdriver, socket wrench.  :D I wonder if there's anything else?
francuz69
« Reply #10 on: February 23, 2021, 09:26:06 PM »
Nope. Just watch out for under seat light cable and external diag port when You remove the seat bucket.
« Reply #11 on: February 24, 2021, 03:22:17 PM »
sounds like you should look up what tools look like on your computer,.  as screw drivers have a lot of sizes philips 0,. 1,. 2,. 3,.
torex screw driver   t 10,. t15,. t20 t25,. t 30,. t 35 ,. t40 and bigger,.  allen Keys Hex ,  Torex, sockets  6 point and 12 point and square metric and american standard,  Im 87 so I use impact drills to take things apart,  small drills , 5 volt.  reg. ones 12 volt,  and corded ones with high power,.  and use a Torque wrench to tighten nuts or you will break them off,  mostly the # 8 and #10 nuts  good luck and happy riding,.
Mace3739
« Reply #12 on: February 24, 2021, 10:20:02 PM »
Hmm a torque wrench is one I don't have, I'll make sure to get one too. This is my first bike, first vehicle ever, really. I want to do the job right.
pa-outdoorsman
  • Pennsylvania
« Reply #13 on: February 24, 2021, 11:03:06 PM »
If you need good tools, cheap, Harbor Freight is your friend.
2018 Kymco UXV 450i
2021 Honda ADV 150
« Reply #14 on: February 25, 2021, 12:51:40 AM »
If no Harbor Freight around..
.tools from the dollar table at local hardware store quite adequate for scooter mechanics.
