Oh yeah, and speaking of that fun manual...before I forget, oswaldters, I wanted to mention that the manual shows two different setups for the front brakes...the drum and the disc brake setup and I get a bit confused with it at times.
So...the service limit I posted (somewhere around here) of 2mm was actually for the drum brake linings, not the disc thickness.
And the brake arm bolts torque specs refers to the drum brake. So if you ever need to work on the front disc brake, the caliper mount bolts' torque specs are really 2.9 - 3.5 kg-m instead of the .8 - 1.2. You definitely don't want those too loose!
And what's up with the manual saying Agility 50 at the top of one page and then Filly 50 at the top of the next.
