Author Topic: Unused, disabled front signal/clearance lights  (Read 1802 times)
Re: Unused, disabled front signal/clearance lights
« Reply #15 on: March 17, 2021, 02:54:36 PM »
Good job Karl!  Anything on a scooter that makes us more visible can only be a good thing - and I speak as someone who has just made an emergency swerve across half the road to avoid a myopic mini driver who tried to take me out at a junction this morning!  My language inside the helmet was choice.
Saved by my habitual defensive riding technique of moving to the centre of the road when passing road junctions.
+1
I always move near the center of the road when lots of cars parked at the curbs. The longer I'm visible to drivers waiting at side streets, the better. Plus, they are more visible to me.
Glad you're OK!
I'm pretty certain that I'm a safer drivet because of my scootering habbits on the roads
« Reply #16 on: March 17, 2021, 03:08:04 PM »
...may have to invest is a couple of LED replacements....
that would increase your light output significantly...and look really good
« Reply #17 on: March 17, 2021, 03:43:41 PM »
Thanks Tom.  With regard to biking skills making you a better driver, I agree 100% and would go further, I'd make a bike licence a stepping stone to your car licence!
FJTRoy
« Reply #18 on: April 06, 2021, 11:45:41 PM »
cool ! so what does it take to get the nose off. or is it better to just go ahead and read all 60 pages of "what did you do to your DT300 today" lol
86FJ1200
07Burgman650
15Downtown300i
« Reply #19 on: April 07, 2021, 11:23:52 AM »
NJ
Read all the 60 pages! Har, har! Takes real patience to find anything like that!
DO NOT START THIS UNLESS TEMPERATURE IS 70°F OR MORE!
1. Remove windscreen, 4@ 6 mm socket head cap screws, 1@ 10 mm hex under the swing away Kymco emblem.
2. Remove 6@ Phillips screws facing rider, all parallel to each other. Leave the two that are angled upward. These are blunt end self-tapping threads.
3. Remove 3@ Phillips screws above front fender, left, right and under center of pointy nose.
4. Remove triangular shiny black cover the single screw under the pointy nose was holding. This thing is a real bear to remove the first time! Put duct tape right along each side of this piece to avoid gouging the main part of the nose fairing when this piece lets go! It has two "plugs" near its upper end that fit into rubbery grommets. This is one of the cosmetic parts that fit real tight. I put dielectric grease on those two plugs when finally removed to make it easier the next time.
5. Remove two 10 mm hex nuts that were covered by that thing removed in step 4.
6. Remove fairing by wiggling pointy nose up, down and around to kinda loosen things up a bit. Then with one hand on the pointy nose and the other a couple of fingers in that big center hole, pull upward until the bottom edges pop out. Then pull straight forward. I have broken no tabs off yet!
WAIT! You have to disconnect two wiring harness before you walk off with this! This event really needs two people but it CAN be done with just one. Use dielectric grease on those plugs so it will be easier next time. Yes, there will be a next time because...well, you will find another reason!
Post when you are ready to put the nose back on! Har, har! Hint: get the bottom, forward edges fit first then tilt it back. Then lift up the black edges at top on one side to get all those "finger" thingys under the edges then do the other side. Make sure all the edges mesh properly. Take time to seat this thing precisely, it WILL fit perfectly. TELL ME YOU FORGOT TO PLUG THOSE TWO HARNESS BACK IN!
« Reply #20 on: April 08, 2021, 02:43:48 PM »
Karl you really are an asset to the Forum with all your detailed knowledge.  I'm sure I speak for many in thanking you for your time, effort and humour.
« Reply #21 on: April 08, 2021, 04:39:38 PM »
Aw, shucks! Thank you!
scooterfan
« Reply #22 on: April 08, 2021, 05:07:35 PM »
Carl you are forgiven. We all love Dolly.
FJTRoy
« Reply #23 on: April 09, 2021, 12:21:39 AM »
  Har, har! . TELL ME YOU FORGOT TO PLUG THOSE TWO HARNESS BACK IN!
 Awesome, Bub ! Thanks! I was afraid step one would be remove seat & tub, then work your way forward :D
86FJ1200
07Burgman650
15Downtown300i
« Reply #24 on: April 09, 2021, 08:36:15 AM »
Iriszaro
« Reply #25 on: June 18, 2021, 04:24:53 AM »
 ;D ;D
« Reply #26 on: June 19, 2021, 02:30:19 PM »
He's a treasure for certain!
« Reply #27 on: June 19, 2021, 02:36:21 PM »
There's a standard riposte for that expression over here...
