Author Topic: Super 8 150--2021---does it have fuel pump?  (Read 492 times)
« on: March 10, 2021, 05:44:27 PM »
Considering buying one---2021 specs say carb (fine with me)----does it have fuel pump? (for me one less thing to mess with)
Re: Super 8 150--2021---does it have fuel pump?
« Reply #1 on: March 10, 2021, 06:13:15 PM »
John, looking at a parts diagram online it looks like it just has a regular vacuum operated petcock from the rear, high mounted fuel tank.
« Reply #2 on: March 10, 2021, 07:05:39 PM »
Thanks---no pump=another thing that will not go wrong!
« Reply #3 on: March 11, 2021, 03:23:55 PM »
No fuel pump to worry about but I think that the Fuel filler is under the seat.  That means if you have stuff bungeed on the back of the seat you have to remove it every time you fill up and with a 1.3 Gal tank that will happen a lot.  That was one of the things I didn't like about my Super 8.  I did find I could bungee a small bag directly to the seat so I didn't have to remove it to fill up.
JJJoseph
  • Kymco Sento
« Reply #4 on: March 14, 2021, 07:11:11 AM »
Small scoots usually carry the load on the floor (see photo), so it's common to have rear fuel tanks.  TBH, I'm not sure how this model carries its freight, though. Also, FWIW(!), carbureted Kymcos are much much easier to live with long-term than the fuel-injected models.
« Last Edit: March 14, 2021, 07:13:14 AM by JJJoseph »
