Author Topic: Stuck cylinder jug / Unable to remove cylinder Jug  (Read 1329 times)
mhaseebalam
« on: March 11, 2021, 05:42:22 PM »
Hi all,
I had a gasket leak and maybe some piston damage as well so I was going to do a 70cc Mezoly Kit. However, im stuck at removing the cylinder jug. I tried hitting it with the back of the Rachet and as well as a rock with cloth in between of course but it just wont move. I am able to turn the engine over but I do hear the rings scratching agasint the cylinder jug. Any suggestions?
eamartin
Re: Stuck cylinder jug / Unable to remove cylinder Jug
« Reply #1 on: March 11, 2021, 06:26:47 PM »
Photo?
mhaseebalam
« Reply #2 on: March 11, 2021, 09:05:23 PM »
it's a stock kymco agility which I believe is similar to the GY6 Engine.
eamartin
« Reply #3 on: March 11, 2021, 11:29:03 PM »
I like to use a block of wood and a good hammer.  Hit it from all directions you can reach - left, right, top and bottom if you can.
mhaseebalam
« Reply #4 on: March 12, 2021, 06:58:55 PM »
JJJoseph
  • Kymco Sento
« Reply #5 on: March 14, 2021, 05:58:13 AM »
Amen to that.  You can't hurt it any more than it's already hurt.  If the piston moves, it's only the base gasket that's holding it in place. I have a heavy rubber mallet that works every time.  Cylinders are cheap anyway.
« Last Edit: March 14, 2021, 06:39:01 AM by JJJoseph »
Onekneedown
  • ride more, talk less
« Reply #6 on: April 20, 2021, 06:46:42 AM »
I had that same issue and put the top end back on again for a day or 2 before trying a seçond time.   Tapped it with a small hammer and eased right off.   If you have the new cylinder waiting to go on, knock it off with a good smack of a mallet!!
