Author Topic: People 50 - CDI restricted?  (Read 7054 times)
ezrae
« on: October 18, 2010, 02:29:52 AM »
Hi!  I have a 2009 People 50 and I'm trying to figure out if the CDI is actually derestricted.
When I pull the green wire out of the CDI the scooter won't start.  There's no other disconnected green wires laying around and there's only one green wire in the CDI.
Any ideas?
Peters
  • In Glock I Trust
Re: People 50 - CDI restricted?
« Reply #1 on: October 18, 2010, 04:41:07 AM »
Welcome. 2 stroke or 4 stroke? Have you derestricted the boss drive in the CVT yet? If you can't get much more than 30mph then the CVT is restricted. Do that first. Then it seems the only way to tell is to run it wide open down a nice long hill and if you can hit 50mph, or close to it, without it cutting out you are derestricted(except that stock exhaust). My 09 had a green wire with a bullet type connector I unplugged right after I got it. I don't know if that did anything or not. I know it never cuts out though(52-53mph top speed downhill indicated).
« Last Edit: October 18, 2010, 04:44:29 AM by Peters »
*2001 ZX-50 beater
« Reply #2 on: October 18, 2010, 04:45:42 AM »
..my 2007 tops out at 52-53 downhill...
..has the restricted oem exhaust, oem airbox and main jet...
..but it carries my 225 lb ass  uphill like a raped ape!!..
 ;D
ezrae
« Reply #3 on: October 18, 2010, 04:48:15 AM »
It's a 2 stroke.  The boss is derestricted.  I can't go more than 45 on a downhill, no matter how I try.  I can't hit more than 35 if I'm lucky going uphill and I'm only 145lbs.
I have a friend with a brand new People 50, derestricted by the dealer, and he leaves me in his dust both up and down hill.
« Reply #4 on: October 18, 2010, 04:50:21 AM »
...wow..sounds like the cdi...hmmmm...
Peters
  • In Glock I Trust
« Reply #5 on: October 18, 2010, 04:52:28 AM »
Yep sure does
Maybe 55mph I don't know Im guessing cause the speedo(numbers) stop at 50. Really I didn't gain much downhill speed. Flat ground and up hill is much better though.
« Last Edit: October 18, 2010, 04:56:24 AM by Peters »
*2001 ZX-50 beater
Rianna
« Reply #6 on: October 18, 2010, 04:53:53 AM »
Did ya buy it new, ezrae, or is it possible someone put a different CDI in it?
« Reply #7 on: October 18, 2010, 04:55:30 AM »
...speedometer on my 2001 goes up to 60 mph...07 only goes to 50...
Rianna
« Reply #8 on: October 18, 2010, 04:57:48 AM »
Hmm...did a law change somewheres between 2001 and 2007?
« Reply #9 on: October 18, 2010, 05:03:07 AM »
..maybe, but it seems that the pre 2005 ppls have a virtually unrestricted exhaust...
ezrae
« Reply #10 on: October 18, 2010, 05:05:56 AM »
Yeah, I kinda figured that.  So what's up with the green wire?  It won't start if I disconnect it, so what else can I do?
« Reply #11 on: October 18, 2010, 05:08:29 AM »
..maybe art will know...
..i do not...
ezrae
« Reply #12 on: October 18, 2010, 05:09:31 AM »
I bought it used, but the CDI is definitely stock.  I checked the part number (30400-KFA6-9000) with the parts manual.
Rianna
« Reply #13 on: October 18, 2010, 05:17:50 AM »
I'm googling that part # like crazy, exrae. Not finding anything about derestricting it, though. It does look like that CDI is used in ATVs and other scoots, though, so there should be some information about it somewhere.
Rianna
« Reply #14 on: October 18, 2010, 05:27:48 AM »
Googling the People 50 CDI derestriction brought up this, though. It lists earlier years and gives a Kymco technical phone number to call with questions.
http://scooterdiva.com/manuals/kymco/Kymco_Derestriction.pdf
