I *may* have found your vibration/thump. I just got done swapping my rollers out for 15g sliders. And I was able to create what think is the effect your talking about.
With everything apart I tried creating this issue and I was able to under the following conditions.
1) rollers or sliders werent seated right.
2) the variator bolt wasn't torqued enough. This one's a hard one is the spec is so open about how much to torque the bolt.
3) a variation on #1
Basically what I could recreate was the variator would break loose or snap out de-accelerating under 2800-4200 rpms. It appears the belt applies to much press and there isn't enough resistance from the variator to slowly move back out to it's at rest location and it just jump out alittle.
Is that right!! Interesting...most interesting...
Thank you for the help by the way! Immensely appreciated.
The only thing that comes to mind as i mull that over is that it DOESNT do it, under any load or RPM unless i get it up to about 40 mph...that makes me think it has something to do with the secondary pully (driven pully) returning to its fully open state because i think that one doesnt start to close until you get moving a bit...I THINK...I had it in my head that the variator end closes up first off.
I might have that all backward...i do that a lot
Another thing is that if i brake real hard i cant feel it NEARLY as much...more of a little "pop" is all
But if i let the engine slow it down and dont use the brakes as much it becomes a bit of a "bang"
Happens right at 23mph either way
Approaching 1500 miles and it doesnt seem to be getting any better OR any worse...Which is kind of annoying on its own!
![Cheesy :D](https://www.kymcoforum.com/Smileys/default/cheesy.gif)
