Author Topic: Wont Start  (Read 1967 times)
Jamesx03
Wont Start
« on: March 21, 2021, 06:06:36 PM »
Okay so I have the Kymco people 300 2013
I have a battery newish from September.. Now I tried to start the thing after not using for a couple of months (5 to be exact). Nothing happened I kept trying it lights are on there's gas, the battery seems fine. Just to double-check maybe the battery didn't have enough power hooked it up to the car tried to start it and silence. I turned the kill switch ON (thought it was faulty) obviously it didnt start, turned it off, same thing. No noise at all. Not sure what to do now. OR if I need a new spark plug, starter or anything I'm not sure where to go. I am not a car guy I am smart enough to look at a manual and tinker but I'm no mechanic. I can do this stuff myself just dont know where to look for parts or what troubleshooting I should do, besides the basics of what I already attempted. Can anyone help me or let me know if I need to provide any more information.
okay so i saw the other post for the Powersports to get parts, But I and not to sound like a complete idiot have no idea after searching where those parts would be located (I have never really worked on any mechanics other than changing the oil and tires on a car and oil on my Kymco lol)
« Last Edit: March 21, 2021, 06:12:20 PM by Jamesx03 »
Re: Wont Start
« Reply #1 on: March 21, 2021, 11:11:09 PM »
What does "no noise" mean? No starter noise, no cranking noise or no running noise? Or no all three noise?
Jamesx03
Re: Wont Start
« Reply #2 on: March 23, 2021, 05:55:49 PM »
All three. I turn the key and nothing happens. The Bike turns on but its just I guess running on the battery. Theres no "cranking (?) " it just like I didnt turn the key at all
Re: Wont Start
« Reply #3 on: March 23, 2021, 07:34:29 PM »
Key on before start sequence:
1. Key on
2. Speedo goes full scale back to zero.
3. Fuel pump runs for short time (2 seconds).
4. All symbols light up on instruments, all symbols display on LCD.
5. All symbols go dark, LCD displays fuel state and cold temp.
6. Head light, tail light, side lights come on. Turn signals armed.
Key on start sequence
1. Start button pushed, starter immediately spins engine.
2. Engine fires after second revolution (noermally) and runs.
I know you know this last part! What we do know at this point is the lights are on, no starter spin, no fuel pump noise. Need you to tell if that other stuff is on or not. The kill switch and sidestand switch just kills the ECU. The starter should spin.
Re: Wont Start
« Reply #4 on: March 23, 2021, 08:01:57 PM »
Maybe brakeswitches defect?
Re: Wont Start
« Reply #5 on: March 23, 2021, 10:36:02 PM »
Would prevent starter turning but not fuel pump prime.
Jamesx03
Re: Wont Start
« Reply #6 on: March 24, 2021, 05:29:35 PM »
1. Key on
Okay, and thank you for breaking it all down, Im trying to explain it correctly haha. Um so I can get to number 6. Everything seems good, press the start button and nothing happens. All the lights are on, the blinker works, LCD is showing everything it usually does, fuel, the battery light is on briefly to signal I am running on the battery. I have the key on ignition but Im I guess at this point the starter does not spin.
So (since its relatively cheap and we just did get those nice stimmy's) I wanted to start by replacing the Starter. Again I have the Kymco People 300, 2013. I have done some googling on the starters and I get some options but nothing specifically says its for the Kymco people (which I assumed would happen) and I just dont know what a good purchase for the starter would be.
« Last Edit: March 24, 2021, 05:32:48 PM by Jamesx03 »
Re: Wont Start
« Reply #7 on: March 24, 2021, 07:33:52 PM »
Could be that one,
VICMA VIC-15626
..check at the rear end this two prongs...
Re: Wont Start
« Reply #8 on: March 24, 2021, 08:10:02 PM »
Since the engine-trans units are the same People GT300i/Downtown 300i the starters are probably the same. Impossible to tell generally from parts lists but it may be used in several models 250 to 350 cc. However, would it not make more sense to isolate the exact cause of the problem before ordering parts?
Re: Wont Start
« Reply #9 on: March 24, 2021, 08:13:59 PM »
But try to bridge your starter motor before you buy a new one like (pls see pics)to make sure its the starter, which is faulty.
Re: Wont Start
« Reply #10 on: March 25, 2021, 01:18:37 AM »
What Ruffus said..
Jamesx03
Re: Wont Start
« Reply #11 on: March 25, 2021, 11:53:29 PM »
Okay this is a good place to start thank you ill reply with some updates :)
roxyflash
Re: Wont Start
« Reply #12 on: April 02, 2021, 11:23:37 PM »
I have a good used starter 2015 date o it if interested
