Author Topic: Top Speed 2021 Super 50 cc  (Read 5029 times)
gjx
« on: March 26, 2021, 10:54:46 AM »
Top speed for 2021 Super 8 50 cc?
What is the top speed on a flat road w a 175 LBS rider? I am getting 26 mph and not higher.
I understand restrictors are  on on it, but shouldn’t it be faster even w the factory restrictions?
Is it a warranty issue for a dealer to address so that it gets to 30 MPH or more?
Thx!
Tseg
Re: Top Speed 2021 Super 50 cc
« Reply #1 on: April 19, 2021, 04:01:32 PM »
I have a 2016 Super 8 50cc, which I think was the first year of this newest design.  I weigh 220lbs.  When new, I could get to about 24mph.  I did 4 things and now easily get to 32-33 on a flat road... slight downhill up to 35mph.
  • On the CDI, pulled out one of the purple/red wires and cover end with electric tape (I can re-insert if needed)
  • I bought an unrestricted (no collar) variator boss and had the scooter shop install it
  • I only use Mobil 1 5W-30 synthetic oil and Mobil 1 85W-90 gear oil, which I install myself annually
  • I disassembled the intake manifold to the carb and removed a washer jammed in there that restricts air flow
I've considered other mods but I know every next mod tends to throw something else out of whack... endless cycle.
I have taught myself how to do valve adjustments, replaced spark plugs and adjust the idle.
When cold/cool, my throttle will bog down (cut out) under quick acceleration... which diminishes the warmer the engine gets and the warmer the air temperature gets.  If the temp is only is the 60's it will take a mile or two to have that bogging issue all but disappear... the warmer the air, the quicker the issue goes away.   I think I have about 3400 miles currently on the scooter.  I got the scooter for my son, but he is now in college and did not take it with him, so it has become my project to maintain it and take it for 20 minute joy rides now and again.   It once had gas in it for 2 years and had been nearly a year since started... I had to empty the tank, and give it fresh gas with some Sea Foam... it took about 20 minutes trying to start it with a few battery re-charges, but finally got it going.  I think now it is running as good as it ever has.   Don't leave gas in it over the winter.
The Super 8 is a good looking scooter, but it is a bit heavy, which I think makes it slightly slower than the Agility.  Good luck sorting it all out.
Rjconway86
« Reply #2 on: May 26, 2021, 09:27:25 PM »
Thx!
Mines exactly the same. Dealer said they have no obligation to hit 30...only stay under 30
JJJoseph
  • Kymco Sento
« Reply #3 on: May 27, 2021, 06:34:28 AM »
Thx!
No, standard top speed for a 50cc machine in the USA is 26mph.  This is the legal limit in some states that don't require licence or insurance, so it gets applied to all 50cc scoots.  They can be modified with Chinese speed parts to get slightly over 30mph.  Remember, though: the faster you can make it go, the sooner it's going to blow up!
« Last Edit: June 06, 2021, 07:07:58 AM by JJJoseph »
Rjconway86
« Reply #4 on: June 05, 2021, 02:23:41 AM »
2020 getting 35 and 38 on a long stretch In a tuck. New Variator, 6.9 gram rollers, up jet to 82, and tuned it up.
Thx!
JJJoseph
  • Kymco Sento
« Reply #5 on: June 11, 2021, 06:47:56 AM »
Keep us posted when it blows up so we can make a mental note!
Roytheroach
« Reply #6 on: September 02, 2021, 10:13:38 PM »
I have 1100 miles on my 72cc build and most of that was at 47mph. They can handle quite a bit.
JJJoseph
  • Kymco Sento
« Reply #7 on: September 04, 2021, 08:11:33 AM »
It's just getting broken in.  Wait for it!  When BBKs blow up, they make a grinding, crunching sound and then they stop gracefully.  Then you get to do it all over again!
eamartin
« Reply #8 on: September 04, 2021, 12:26:35 PM »
Roy,  What year is your Super 8?
Roytheroach
« Reply #9 on: September 05, 2021, 05:58:39 PM »
I broke it in for about 100 miles and it's been just fine. If it blows up that's an excuse to go up to a 57mm spacing case lol
2015 bought and bored in 2016
Love My Kymco Cobra
« Reply #10 on: September 08, 2021, 12:09:27 PM »
Can someone tell me how to start a new post here. Looking for a cdi box for a 2001 Kymco cobra racer with the green wire coming out the bottom.Thank you for any help
eamartin
« Reply #11 on: September 08, 2021, 12:57:21 PM »
Go to the home page, scroll down to the appropriate category (ZX50?), click on this category, near the top with dark background is "New Topic".  Click on "New Topic" and begin.
