Author Topic: Agility 125 hard to start  (Read 1841 times)
Footsoldier2008
« on: April 02, 2021, 01:18:21 AM »
My 2015 agility 125 starts but cuts out often. And will sometimes sound like an old 2 stroke. I've checked the fuel spark ect. I will check the valves today but I've seen on other posts it could be the cdi? Any help greatly appreciated
Re: Agility 125 hard to start
« Reply #1 on: April 02, 2021, 02:21:08 AM »
can you expand on  it 'cuts out often'?  Dies right after starting? Dies when you first give it gas? Dies while riding? That can help narrow down potential problems.
Footsoldier2008
« Reply #2 on: April 02, 2021, 04:10:05 AM »
Dies after a couple of minutes. And also once when I was stopped at traffic lights.
Many thanks
scooterfan
« Reply #3 on: April 02, 2021, 04:56:10 AM »
If the valves are okay it could be a fuel problem, or the CDI on your scooter is dying.
If the engine starts easily after a cuple of minutes (after the engine died) it should not be a fuel problem - the CDI is most probably on it’s way out. I would then just install another one without fiddling elsewhere.
Kymco Agility 125
Honda Silverwing 600
Suzuki Boulevard C50T
Footsoldier2008
« Reply #4 on: April 02, 2021, 05:35:34 AM »
Yeah it starts fine after a couple of minutes just keeping the dam thing running.
Cheers for your advice
aschrauth
« Reply #5 on: April 02, 2021, 07:53:44 PM »
 My bike had the same problem. Narrowed it down to the CDI, replaced it with an aftermarket one and no problems so far. My OEM cdi went out at around 1,000km. Which supprised me considering the low mileage
Kymco 125cc
Wolf Rx50 BBK 80cc
scooterfan
« Reply #6 on: April 03, 2021, 06:45:41 AM »
The CDI’s and Voltage Regulators are the “weak spots” on the Agility 125’s. Those two components are “must have” components as spare parts at all times. At just over 28 000km my Agility is on it’s 3rd CDI and 3rd Voltage Regulator as well. I never ride around without those two spare components inside the luggage box. The spare components got me going within minutes each time I experienced problems along the road.
Kymco Agility 125
Footsoldier2008
« Reply #7 on: April 03, 2021, 02:41:08 PM »
I have now checked the valves and set them up correctly.
I have a new cdi coming today and will fit that also will hold a regulator aswell. Thank you very much
scooterfan
« Reply #8 on: April 03, 2021, 03:24:54 PM »
Did you find the valve clearance gaps too tight ? If not, I am almost prepared to bet my front teeth the CDI on your scooter was dying.
Kymco Agility 125
Footsoldier2008
« Reply #9 on: April 04, 2021, 10:21:31 AM »
Yeah the intake was .003 exhaust was .002.
scooterfan
« Reply #10 on: April 06, 2021, 02:55:18 PM »
Any luck since the valves clearances have been adjusted ?
Kymco Agility 125
Footsoldier2008
« Reply #11 on: April 12, 2021, 01:50:07 AM »
Yeah all good so far
