Author Topic: Agility 125 Euro 6 - Accelerator Cable Change  (Read 715 times)
EVS_125
« on: April 02, 2021, 03:47:08 AM »
My accelerator cable conked our after 7000 kilometers. I decided I need to start doing some things myself on the scooter. Got the part and started the whole dismantling procedure to track the cable. All ok but now I am unable to open up the handle bar cover fairing to access grip mounting.(see attachment). Looked at a lot of sites etc, Any advice on how to proceed ??
Re: Agility 125 Euro 6 - Accelerator Cable Change
« Reply #1 on: April 02, 2021, 08:57:56 AM »
@EVS,
maybe that helps..
Usually this front parts are fixed with 8mm srews and additionaly laced into each other by plastic noses.Pry carefully along gaps with a thin plastic spatula or similar.
« Last Edit: April 02, 2021, 09:01:48 AM by Ruffus »
EVS_125
« Reply #2 on: April 02, 2021, 10:11:30 AM »
Thanks Rufus. I removed all screws and I do have an image of the Agility 6+ Handle bar fairing (not detailed enough) The structure did separate from the lower end ...however the  top seam is immovable. My dilemma is that I do not know the role of  the rectangular frame which covers the instrument panel and  fear that should I keep stressing it further could damage instruments.
I appreciate your hint about the spatula...and will try it. Thanks.
13.01 - Hi Rufus.....Your trick worked a treat"!"!!!!!! a really Good Friday!!!!
I have found the root of the whole issue. The front cone is fixed to the steering column as per photo . Points are marked with a white arrow!! It is the back (black) section that needs to come off...and it includes all the instrument panel in one piece. I can now continue to dismantle accelerator grip. I would recommend that surfaces (close to section including horn etc as per photo) are covered with cloth to avoid scratching.
Have a great Easter!!
« Last Edit: April 02, 2021, 11:09:03 AM by EVS_125 »
« Reply #3 on: April 02, 2021, 12:53:39 PM »
it's a good feeling to find the trick to disassembling one of these...finally understanding exactly how they go together. Good point about protecting the plastics from scratching during this procedure. I have started covering the plastics with painters tape to prevent any scratching.
You may also want to replace your brake fluid while you have the cover apart and easy access.
« Reply #4 on: April 02, 2021, 06:20:44 PM »
@EVS,
wonderful to read it worked. When you assamble your fairing again, put on each "nose" a good smear of silicon grease, helps a lot for next time and makes joining much easier.
EVS_125
« Reply #5 on: April 03, 2021, 03:54:55 AM »
@EVS,
Thanks a lot for your help @Rufus. I enclose diagram of Handle Bar fairing for perusal by readers.
« Reply #6 on: April 03, 2021, 09:43:44 AM »
@EVS,
 thanks for resolve reply and Happy Easter.
« Reply #7 on: April 03, 2021, 02:45:21 PM »
EVS_125....off topic, but I have to ask...you are the 3rd poster in the past 5 years to join this Kymco scooter forum and use the exact same avatart pic of Bono. The first 2 posters both had People S200s and claimed they weren't the same person.
Now i see another new forum member using the same pic. What are the odds that 3 different people would buy a Kymco scooter, join the Kymco forum and use the same avatar pic of Bono?  Curious, indeed....
« Reply #8 on: April 03, 2021, 06:39:47 PM »
I also thought I had seen that avatar before!
EVS_125
« Reply #9 on: April 04, 2021, 03:37:34 AM »
Avatar changed ...reason why Bono chosen in the first place is that it is practically the first thing that pops up on registering and to be honest I was more interested in the forum (problem solving) than anything else. MCs are more of a heritage than anything else for me. Grandpa and my dad in pic dated 1954.
« Last Edit: April 04, 2021, 03:51:28 AM by EVS_125 »
« Reply #10 on: April 04, 2021, 09:25:05 AM »
@EVS,
great to have such heritage to think of!!
Att. a pic on my YAMAHA XT 500 appr. 40 years ago. Was nearly brandnew then. Bike is still in use at a friends.
« Reply #11 on: April 04, 2021, 02:49:41 PM »
Ah, it all makes sense, now! I wasn't aware that avatar pics were offered up to new members upon registering.
Very cool old pic, by the way.
EVS_125
« Reply #12 on: April 06, 2021, 03:56:18 AM »
@EVS,
DTMX 175 in my case bought new > Still have it...but probably seized up...a project but?? who knows.
